Solid State Logic X-Desk Mixer
X-Desk Brings Benchmark Audio Performance to the Compact Mixer Format
Solid State Logic, the world’s leading manufacturer of analogue and digital audio consoles and provider of creative tools for music, broadcast and post production professionals, proudly announced the release of X-Desk at Musikmesse 2009, April 1-4.
Over the past three decades Solid State Logic has designed and built the world’s finest audio consoles. With more than three thousand SSL consoles in use worldwide, the “SSL sound” has become an integral part of countless hit recordings. With Duality, AWS 900+ SE, Matrix and C200 HD, SSL consoles continue to be leaders in the field of high-end music production. The same technology and sound of the SSL console legacy is now available in X-Desk.
The X-Desk is a world class, versatile, portable, extremely high quality, no audio quality compromise compact mixing desk. It combines a 16 channel SSL SuperAnalogue™ summing mixer with a compact analogue audio hub for your studio. Featuring 100mm faders, professionally featured artist and studio monitoring with Dim & Cut buttons, the X-Desk fulfills all of the essentials of the audio mixing process with SSL attention to detail and depth. It also boasts stereo and mono aux sends, channel and master bus inserts and accurate bar graph level metering.
X-Desk is an elegant and ergonomically refined desktop mixer that comes with rack ears for standard 19″ rack mounting (X-Desk is 7U). It is extremely robust as it is hand built in the UK with an all metal chassis and high quality controls and components. Several X-Desks or X-Desk & X-Racks can be cascaded via D-Sub connection to expand up to 150 inputs on mixdown.
Key Features:
  • SuperAnalogue — analogue purity at the highest level
  • 8x dual input Mono Line channels : 16 channel mixdown
  • 8x Insert Send/Returns on channels
  • Stereo CUE and 2 Mono Auxiliary Sends
  • Cascade with X-Rack and other X-Desks for bigger systems
  • Talkback — for artist communication with Dim & Cut buttons
  • Independent Main and Alternate stereo monitor outputs
  • SSL Stereo Mix Bus with External summing and Inserts
  • 2x Stereo Returns with Level, Pan and Bus assignment
  • Stereo External input on XLRs
  • iJack front panel input for portable playback devices
  • High quality internal PSU
  • D-Sub Channel I/O connection for studio integration
  • RF Screened I/O connections
  • 19″ Rack mount ears included
X-Desk will be available from SSL resellers worldwide beginning in May 2009 with a MSRP of $2,899.
Solid State Logic is the world’s leading manufacturer of analogue and digital audio consoles and provider of creative tools for music, broadcast and post production professionals.
TCL QM7K QD-MiniLED TV Lifestyle 2025
HDTV 4K & 8K TV
With sizes up to 115 inches and fairly affordable pricing, TCL's QM7K MiniLED TV will be one to watch in 2025.
Fluance Wireless Floorstanding Speakers Lifestyle Fluance Wireless Floorstanding Speakers Lifestyle
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Arendal 1961 Loudspeakers Arendal 1961 Loudspeakers
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Placing record on Turntable PP-1 from above Placing record on Turntable PP-1 from above
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
EE1 Plus with Cable EE1 Plus with Cable
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Michell Audio Apollo Phono Preamplifier and Muse Power Supply Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
