Solid State Logic Duality SE Console
New Edition of SSL’s Ground Breaking Hybrid Analogue Console & DAW Control Surface Makes the Best Even Better
Solid State Logic, the world’s leading manufacturer of professional digital and analogue consoles, is proud to announce the release of Duality SE at the 127th AES Convention, Booth 321 at the Jacob Javits Center from October 9 to 12.
Duality has firmly established itself as the best music console money can buy and the industry standard for professional audio production. Just like previous generations of classic SSL consoles, Duality achieves its success by enabling engineers and producers to work faster and deliver better results. Its innovative hybrid approach, combining analogue signal path/processing with advanced DAW control within a single hardware surface, has found many fans. Duality has a diverse user base that includes many of the world’s most prestigious commercial recording facilities, on-air broadcast production studios, educational establishments, film & TV score specialists and a growing group of notable private owners.
“It is not easy making the best even better,” states Piers Plaskitt, CEO of SSL Inc. “This new edition of Duality responds to customer feedback by providing a collection of new features and refinements to the core feature set.”
At the center of improvements to the way Duality controls and communicates with DAW applications is the introduction of Ethernet connection between the console and DAW host computer. This single cable approach simplifies installation. The existing MIDI ports on the console are retained and can be utilized for connection of other MIDI equipment, effectively making Duality a MIDI Interface. There is new dual layer DAW control, enabling Duality to control two DAW’s simultaneously with seamless switching of hardware surface controls between manipulations of each DAW layer. The Duality Logictivity Browser has also been refreshed with new features, a streamlined user interface and new visual appearance. The Solo/Cut tiles across all of the consoles channel strips have been replaced with a new set of LCD screens providing more space for a greater level of information and improved viewing angles.
The analogue side of Duality receives 25 individual feature additions, with a few key areas of focus. The Talkback system sees the addition of an Autocue system that provides options to set how the Talkback & Listen switches and Red Light Mode physically operate or respond to Play or Record transport commands. The SSL Automation system has been significantly enhanced with the addition of an Offline Trim facility, selection of Automation Update Status at the head of the mix and the addition of automation for all Cue, FX and EQ insert switches. The Monitor Volume control is also updated with a new Calibration facility, a new ‘fine’ mode that increments in 0.4dB steps and the ability to display in three different modes: FILM (off-95db), Music (1-11) or Gain (off-0db). The TotalRecall™ system also receives an upgrade with the addition of an Autoscan feature that significantly speeds up Recall by conducting a sequential scan of the channels only stopping at those which require attention.
Duality SE is available now. Duality SE (software) is available as an upgrade option to existing Duality customers for $1750.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
