Sol Republic DECK Wireless Speaker
SOL REPUBLIC DECK Wireless Speakers
Sol Republic and Motorola have teamed up to offer the DECK portable wireless speaker, which features 360-degree full sound and a 300-Foot wireless range. DECK is the first wireless speaker with Heist Mode, allowing up to five people to simultaneously pair to the device and control the music. Now everyone can be the DJ and “heist” DECK to share their favorite track or change it up with a different sound. Heist Mode is supported through Bluetooth and Near Field Communication (NFC) and allows for seamless pairing or super-easy “Tap and Play.” To show who has control of DECK, a backlit logo on the speaker changes colors as different users “heist” DECK with a new song.
Powered by R2 Sound Engines, DECK delivers full sounding music and maintains bass in a slim, portable design. Unlike other portable speakers that come with small speaker sound, the extra-large R2 Sound Engines combined with a bass port, high-watt amplifier, and huge lithium ion battery for power offer bigger sound than you would expect from a pocket-sized speaker.
Featuring Outdoor Mode, DECK allows you to press a button for a boost in sound that travels further when you want to listen to music outside. Plus, you can actually walk away from DECK and keep your device in hand with Super Power Wireless range, offering up to 300 feet of wireless range.
With stereo in and out ports you can connect DECK to your home or car audio system and use Heist Mode through your amplified systems. You can daisy-chain multiple DECKs together to create an unrivaled wall of sound. DECK even moonlights as a crystal-clear speakerphone as well so you’ll never miss a call. Use DECK nearly everywhere in its standard, acoustically-transparent case so you can protect it while you listen to it.
Price and Availability
DECK by SOL REPUBLIC and Motorola is available in multiple finishes including Gunmetal, Lemon Lime, Electro Blue and Vivid Red for $199.99. Availability is expected within 30 days.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
