SMSL DL400 DAC/Headphone Amp Debuts With DSD, LDAC and Serious Desktop Ambitions
SMSL’s $499 DL400 features the ES9039MSPRO DAC, 6W balanced power, LDAC support, and a reversible I2S/XLR interface.
SMSL DL400 DAC headphone amplifier black angle
2025 has turned into the year of the DAC and headphone amplifier, with manufacturers pushing harder on features, formats, and actual output power. Our latest DAC/Amp Editors’ Choice list made that clear, and SMSL is stepping into the same arena with the new DL400. It enters a category already crowded with strong options from FiiO, Topping, JDS Labs, Schiit Audio, Rotel, and Burson, so the details matter more than the marketing gloss.
The $499 DL400 is a black-only unit built around ESS’s ES9039MSPRO DAC, the XMOS XU-316 USB processor, and support for PCM up to 32-bit/768 kHz and native DSD512. SMSL claims MQA and MQA-CD decoding, which raises an eyebrow in 2025 considering the uncertainty around long-term MQA support. It will be worth confirming how committed SMSL is to maintaining that functionality through firmware updates.
Clocking is managed by an ultra-low phase-noise design intended to minimize jitter, and the fully balanced headphone amplifier relies on four Precision Linear Feedback Circuit modules and 11 premium dual op-amps. Output power is rated at 6W per channel at 16 ohms, 3W per channel at 32 ohms, and 700 mW per channel at 300 ohms—a relevant number for listeners running higher-impedance Sennheisers and similar designs. Two headphone jacks are provided: 4.4mm balanced and 6.35mm single-ended.
For tuning flexibility, the DL400 includes 8 PCM filter types and 9 “sound color” options. All inputs except Bluetooth support DSD, with coaxial, optical, and AES/EBU handling DoP64. Bluetooth 5.1 (Qualcomm) supports LDAC 24/96 and aptX HD, but not aptX Lossless or Bluetooth LE at this stage. The rear panel adds SMSL’s reversible I2S/XLR professional interface, allowing compatibility with multiple pinout standards.
For a category that keeps evolving, the DL400 looks like another technically ambitious entry. Now we wait to see how it performs against a field that has grown more competitive than ever.
smsl-dl400-front
smsl-dl400-rear
SMSL DL400: Key Specifications
  • Digital Inputs: USB, Optical, Coaxial, AES/EBU, Bluetooth 5.1, I2S (reversible I2S/XLR interface)
  • Analog Outputs: RCA, XLR, 6.35mm headphone, 4.4mm balanced headphone
  • DAC & Formats: ESS ES9039MSPRO; PCM 44.1–768 kHz (32-bit) and DSD 2.8–22.5 MHz (1-bit) via USB/I2S; Optical/Coax/AES to 192 kHz/24-bit; DoP256 (USB) and DoP64 (Optical/Coax/AES)
  • MQA Support: MQA and MQA-CD decoding via USB, Optical, Coaxial, AES/EBU (notable given MQA’s uncertain future)
  • Bluetooth: Qualcomm 5.1 with LDAC, aptX, aptX HD, AAC, SBC (no aptX Lossless or Bluetooth LE)
  • Headphone Power: 6W ×2 @ 16Ω, 3W ×2 @ 32Ω, 700 mW ×2 @ 300Ω
  • Amp Architecture: Fully balanced design, 4 PLFC modules, 11 premium dual op-amps, output impedance near 0Ω
  • Gain: +9.5 dB unbalanced, +15.5 dB balanced
  • Measured Performance:
    • THD+N 0.00005% (line out) / 0.00009% (HPA)
    • Dynamic Range 133 dB (XLR) / 127 dB (HPA)
    • SNR 133 dB (XLR) / 127 dB (HPA)
  • Filters & Tuning: 8 PCM filters and 9 sound “color” modes
  • USB/OS Support: Asynchronous USB; Windows 7–11 (driver), macOS 10.6+ and Linux (driverless)
  • Power Use: <40W operating, <0.5W standby
  • Size & Weight: 250 × 47 × 240 mm (1.74 kg / 3.84 lbs)
smsl-dl400-angle-lifestyle
The Bottom Line
The SMSL DL400 enters a crowded DAC/headphone amp field with a feature stack that actually stands out: ESS’s ES9039MSPRO DAC, the XMOS XU-316 USB engine, a fully balanced amplifier architecture with 11 dual op-amps, and real power—6 watts into 16 ohms and 700 mW into 300 ohms—enough to handle everything from sensitive IEMs to high-impedance classics. The reversible I2S/XLR interface gives it professional flexibility you rarely see at $499 USD, and the combination of 8 PCM filters, 9 sound-color modes, and wide DSD/PCM support lets users fine-tune the DL400 far beyond the usual SMSL template.
LDAC and aptX HD are onboard, though the lack of aptX Lossless and Bluetooth LE is worth noting. MQA and MQA-CD decoding are listed, but how meaningful that is in 2025 remains an open question. Still, with strong measured performance, a clean analog stage, and serious output capability, the DL400 has enough distinctive engineering to make it a compelling desktop centerpiece in a year full of heavy competition.
Where to buy: $499 at Amazon | S.M.S.L.
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Can SMSL’s new R100 and D400 MK2 compete with FiiO, Schiit and Topping in the increasingly crowded DAC market below $1,000?
Can Topping’s $119 DX1 II outfeature Schiit and FiiO with 4.4mm balanced headphone output, PEQ, optical I/O, and console support?
High-power headphone output, Bluetooth 5.4 with lossless codecs, PCM768/DSD512 support, multiple digital and RCA analog inputs in one compact DAC/amp.
Can iFi’s $4,499 iDSD PHANTOM be the ultimate headphone DAC/amp and streamer, with tube/solid-state modes, DSD2048, K2HD, and Class A power?
Class D amps from $130 to $50,000—pulling more ears into hi-fi without demanding you sell a kidney. Solid tech, serious power, and none of...
Hi-Fi Components
If you’ve ever bought affordable Hi-Fi gear—like DACs, headphone amps, speakers, or accessories—from Chinese giants like AliExpress or directly from brands like Topping, SMSL,...
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
