The redesigned SmartMount Pull-Out Swivel Mount optimizes the viewing experience and simplifies installation.
New Tilt Feature Optimizes Viewing
The SP850’s new tilt feature enables screen adjustment for an optimal viewing angle. Its tilt locking option enables the flat panel screen to be set at 0, 5 and 10 degrees, ideal when a precise and uniform alignment of multiple screens is required. For use in public environments, such as houses of worship, educational facilities and corporate offices, the tilt-enhanced SmartMount allows multiple viewing angles and is designed with arms that can be retracted into a two-inch wall plate, concealing all hardware and cables.
Quick and Easy Roll Adjustment
The new feature allows installers to adjust horizontal leveling of the screen at the time of installation for perfect screen alignment, especially in recessed applications or in multi-screen installations. The screen serviceability is also made easy with its smooth extension of up to 10.75″ from the wall and up to 45 degrees left and right swivel, depending on the screen size.
The SP850 ships fully pre-assembled and includes security and safety screws that deter theft and disable extension and movement capabilities of the screen when needed. Available in black and silver, it is compatible with VESA 100 and 200 mounting hole patterns and supports non-VESA screens with additional PLP adapter plates for use with essentially any 26″-50″ screen.
Please visit www.peerlessmounts.com or contact customer care at (800) 865-2112 to get details and place your order.
3215 W. North Avenue,
Melrose Park, IL 60160 USA,
Phone (708) 865-8870
Fax (708) 865-0760
