Simaudio Unveils the MOON Voice 22 Loudspeaker
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it offers.
Simaudio MOON Voice 22 Stand-mount Loudspeakers in white and black
Montreal-based, Simaudio has been been in the high-end audio game for decades and we’re really big proponents of their equipment for the simple reason that they are built like tanks and the sound quality never disappoints.
Their LP110 V2 Phono Preamp makes our “Best Affordable” list every single year because it’s one of the best below $1,000 ($600 USD) and we can’t recommend it highly enough.
This is not a company that rushes anything into the market in response to its competition; they have proven that slow and steady wins the race and you would be hard pressed to find customers who don’t love their systems.
Some of their products introduced during the past decade still being offered include the following.
Building on its audio component expertise, Simaudio has decided to make its first move into the loudspeaker space with the MOON Voice 22 bookshelf speaker.
Simaudio MOON Voice 22 Speakers Black Lifestyle
The Voice 22 Bookshelf Loudspeaker
The enclosure employs a unique patent-pending technology called CGD (Curved Groove Damping) to control the panel resonances of the loudspeaker. This allows the Voice 22 to deliver precise sound clarity with a wide soundstage with emphasis on reproducing small details and clean bass.
The Voice 22 can be used with almost any amplifier but is a perfect match for a Simaudio MOON amplifier.
The Voice 22 can be placed on any solid surface with its integrated Hover base or an optional Bespoke stand
The Hover base is designed to provide stability and reduce vibration, in addition to giving the speaker an elegant ‘floating’ appearance. The stand provides a secure base and adds a striking visual dynamic. The Bespoke stands are made from powder-coated stainless steel. You have the option of spikes or rubber feet.
Whether placed on the Hover base or Bespoke stand, the MOON Voice 22 will complement any décor while delivering room-filling sound.
The enclosure design has a modern feel with a classic twist that recalls Simaudio’s 1980 decade beginnings. The speaker drivers feature sleek baffles and machined bezels for a graceful appearance.
Simaudio MOON Voice 22 Bookshelf Loudspeakers in white angle
Specifications
Structure: Two-Way Bookshelf Speaker
Tweeter: 29mm soft dome with waveguide
Woofer: 155mm mineral-filled polypropylene cone
Sensitivity: 89dB/2.83V/1m
Impedance: 6Ω
Recommended Power: 50W – 150W
Frequency Response (±3dB): 55Hz – 24kHz
Frequency Range (-6dB): 45Hz – 30kHz
Crossover: 1.5kHz
Dimensions (W x H x D):  7.87 x 13.77 x 11.41-inches (20 x 35 x 29cm)
Weight: 23.1 pounds (10.5k)
Finish: High Gloss Black or White with magnetic cloth-covered grills.
Simaudio MOON Voice 22 Bookshelf Loudspeaker in black with grille
Price and Availability
The Simaudio Moon Voice 22 loudspeaker pair is priced at $3,000 (US), $3,800 (Canada), €3,000 (EU), and £2,650 (UK) and is available from Authorized Simaudio Dealers
The optional Bespoke Voice 22 stands are priced at $400 (US),  $500 (Canada),€480 (EU), and £495 (UK) also through Simaudio Dealers.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
