Simaudio MOON 810LP Phono Preamplifier
Simaudio announced the MOON 810LP Phono Preamplifier, offering a dual-mono fully balanced differential design, an ultra-refined audio circuit which is mounted on a floating suspension and fed by a unique power supply. Its highly configurable nature — selectable gain, impedance loading, capacitance loading and equalization curves — is accomplished using DIP switches found on the bottom panel. The switches are located directly in line with the circuit at optimal locations to yield the shortest possible signal path. These adjustments, in conjunction with an excellent overload margin, allow the MOON 810LP to work with virtually any available phono cartridge.
The oversized power supply, located within the main chassis, is housed in an isolated enclosure that is constructed from satin coated 14-gauge steel to eliminate all traces of AC artifacts. Within this enclosure is a high quality toroidal transformer, a “pi-type” filter to reduce AC transmission noise and multiple stages of voltage regulation. Finally, on the actual audio circuit, there are 4 stages of M-LoVo — an all new proprietary MOON low voltage DC regulation circuit. Combining all of these factors, the MOON 810LP’s power supply exceeds the performance of a battery power supply with respect to both audio signal-to-noise ratio and voltage regulation.
Simaudio MOON 810LP Phono Preamplifier - black
Features:
  • The dedicated audio circuit board is mounted on a 5-point gel-based floating suspension which is derived from their M-Octave technology, originally developed for the reference MOON 850P Preamplifier.
  • 4 stages of newly developed M-LoVo MOON low voltage DC regulation circuit; a highly sophisticated circuit made up of a clever combination of IC’s and discrete parts that is virtually free of noise, yielding an exceptionally fast, precise, and stable DC voltage. The result is a power supply with a noise floor of -150dB related to 1.0V, DC – 100kHz.
  • Adjustable impedance loading – 64 available settings from 12.1Ω to 47kΩ
  • Adjustable capacitance loading – 16 available settings from 0pF to 1120pF
  • Adjustable gain settings – 16 available settings from 40dB to 70dB
  • Selectable equalization curves for both the RIAA and the IEC standards
  • Power supply voltage regulation includes i2DCf (Independant Inductive DC Filtering); There is one inductor dedicated to each integrated circuit type component (DAC, Op-Amp, etc.) in the audio circuit’s signal path – 24 stages in all
  • Customized parts include metallized polypropylene film capacitors with very tight tolerances of 1%
  • Four-layer PCB tracings with dedicated ground and power planes using pure copper for low impedance characteristics. The advantages include better circuit layouts resulting in a much shorter signal path and a vastly improved signal-to-noise ratio
  • Power supply featuring a “pi-type” filter comprised of 35,200µF of capacitance and dual choke inductance (2x 200mH)
  • Accurate matching of the very finest quality electronic components in a symmetrical circuit design
  • The shortest possible signal path for a faster transient response and the lowest possible noise floor.
Price and Availability
The Simaudio MOON 810LP will be available in February 2012 for $12,000.
Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
MOON by Simaudio's NORTH Series offers a completely new approach to high-end network streamers/DACs and power amplifiers.
MOON by SimAudio's 250i v2 Integrated Amplifier now represents the entry point into their award-winning range of components.
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it...
Your turntable may not sound great without the right phono preamp. Our Editors' Choice 2022 Phono Preamplifier options offer great performance for the money.
FOR IMMEDIATE RELEASE – August 26, 2004 Simaudio Ltd. proudly announces the introduction of the new MOON Calypso DVD Transport/Player, our newest addition to...
Simaudio Ltd. proudly introduces the MOON P-8 Preamplifier. A fully-balanced differential dual-mono design housed in 2 separate chassis, the P-8 is a masterpiece that...
CD Players
Simaudio Ltd. proudly introduces the MOON Andromeda CD Player. A fully-balanced differential design housed in two separate chassis, the Andromeda represents an “all-out assault”...
