Simaudio MOON 610LP Phono Preamplifier
Simaudio Moon 610LP
Simaudio Ltd. announced the Evolution Series MOON 610LP Phono Preamplifier, a dual-mono, fully balanced differential design, that is heavily based on the reference grade MOON 810LP, a model which has received continuous accolades since its launch one year ago.
The MOON 610LP combines customized parts in an ultra-refined audio circuit which is fed by a unique power supply. This oversized power supply, located within the main chassis, is housed in a satin coated, 14-gauge steel isolated enclosure which eliminates all traces of AC artifacts. Located within this enclosure is a high quality toroidal transformer, a “pi-type” filter to reduce AC transmission noise and multiple stages of voltage regulation.
The 610LP is a purist design that is highly configurable – selectable gain, impedance loading, capacitance loading and equalization curves – accomplished using DIP switches found on the bottom panel. These switches are located directly in line with the circuit at optimal locations to yield the shortest possible signal path. These adjustments, in conjunction with an excellent overload margin, allow the MOON 610LP to work with virtually any available phono cartridge..
Features:
  • Adjustable impedance loading – 64 available settings from 12.1Ω to 47kΩ
  • Adjustable capacitance loading – 16 available settings from 0pF to 1120pF
  • Adjustable gain settings – 16 available settings from 40dB to 70dB
  • Selectable equalization curves for both the RIAA and the IEC standards
  • An oversized power supply producing a DC signal with a noise floor of -140dB related to 1.0V, DC-100kHz
  • Power supply voltage regulation includes i²DCf (Independant Inductive DC Filtering); There is one inductor dedicated to each integrated circuit type component (DAC, Op-Amp, etc.) in the audio circuit’s signal path – 24 stages in all
  • Customized parts include metallized polypropylene film capacitors with very tight tolerances of 1%
  • Four-layer PCB tracings with dedicated ground and power planes using pure copper for low impedance characteristics. The advantages include better circuit layouts resulting in a much shorter signal path and a vastly improved signal-to-noise ratio
  • Power supply featuring a “pi-type” filter comprised of 35,200uF of capacitance and dual choke inductance (2x 200mH)
  • Accurate matching of the very finest quality electronic components in a symmetrical circuit design
  • The shortest possible signal path for a faster transient response and the lowest possible noise floor.
Price and Availability
The Simaudio MOON 610LP will be available in March 2013 for $7,000.00 USD.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
MOON by Simaudio's NORTH Series offers a completely new approach to high-end network streamers/DACs and power amplifiers.
MOON by SimAudio's 250i v2 Integrated Amplifier now represents the entry point into their award-winning range of components.
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it...
Your turntable may not sound great without the right phono preamp. Our Editors' Choice 2022 Phono Preamplifier options offer great performance for the money.
FOR IMMEDIATE RELEASE – August 26, 2004 Simaudio Ltd. proudly announces the introduction of the new MOON Calypso DVD Transport/Player, our newest addition to...
Simaudio Ltd. proudly introduces the MOON P-8 Preamplifier. A fully-balanced differential dual-mono design housed in 2 separate chassis, the P-8 is a masterpiece that...
CD Players
Simaudio Ltd. proudly introduces the MOON Andromeda CD Player. A fully-balanced differential design housed in two separate chassis, the Andromeda represents an “all-out assault”...
