CD Players
Simaudio launches the MOON SuperNova Balanced CD Player
Simaudio Ltd. proudly introduces the MOON SuperNova CD Player. A fully-balanced differential design housed in a single chassis, the SuperNova raises the bar on the CD Red Book digital standard, producing an astonishing level of sonic performance with no equal in its price range. This achievement is the result of a combination of extensive R&D yielding new proprietary technologies and the use of the very finest electronic parts available. To push the envelope even further, the SuperNova can be fully integrated into a custom-install environment and provides for a plethora of user selectable cosmetic options.
“Celebrating 25 Years of Excellence”
Significant Design Features:
  • Internal 24-bit/352.8kHz digital audio processing.
  • Ultra high-perfromance 24-bit “Digital To Analog” conversion.
  • Full unsolicited RS-232 bidirectional feed back.
  • Fully balanced differential circuit design.
  • Digital input for use as a digital-to-analog converter with either a digital music server or another source.
  • S/PDIF and AES/EBU digital outputs for added flexibility.
  • Separate digital & analog power supplies using two independent toroidal transformers.
  • A very precise 25PPM digital clocking circuit.
  • Power supply voltage regulation includes I2DCf (Independent Inductive DC Filtering); 1 inductor for each and every chip (i.e. OpAmp, DAC, Digital Filter, etc.) in the audio circuit’s signal path.
  • C4 Aesthetics: 24 end-user selectable cosmetics combinations: the MOON Logo can be chrome (standard), gold or pewter; leg cones can be chrome (standard) or gold; Front panel cheeks can be silver (standard) or black; Brushed/Anodized front face-plate can be silver or black.
  • A capacitor-free signal path using a DC servo circuit.
  • Proprietary 6db/octave analog filter.
  • Four-layer PCB tracings with dedicated ground and power planes. The advantages include better ground and power supply circuit layouts resulting in a much shorter signal path and a vastly improved signal-to-noise ratio.
  • Extremely rigid chassis construction to minimize the effects of external vibrations.
  • Accurate matching of the very finest quality electronic components in a symmetrical circuit design.
The MOON SuperNova will have an MSRP of $4,500.00 USD.
Scheduled date of availability – August 2005
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
MOON by Simaudio's NORTH Series offers a completely new approach to high-end network streamers/DACs and power amplifiers.
MOON by SimAudio's 250i v2 Integrated Amplifier now represents the entry point into their award-winning range of components.
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it...
Your turntable may not sound great without the right phono preamp. Our Editors' Choice 2022 Phono Preamplifier options offer great performance for the money.
FOR IMMEDIATE RELEASE – August 26, 2004 Simaudio Ltd. proudly announces the introduction of the new MOON Calypso DVD Transport/Player, our newest addition to...
Simaudio Ltd. proudly introduces the MOON P-8 Preamplifier. A fully-balanced differential dual-mono design housed in 2 separate chassis, the P-8 is a masterpiece that...
CD Players
Simaudio Ltd. proudly introduces the MOON Andromeda CD Player. A fully-balanced differential design housed in two separate chassis, the Andromeda represents an “all-out assault”...
