Simaudio launches the MOON P-8 Reference Differential Dual-Mono Preamplifier
Simaudio Ltd. proudly introduces the MOON P-8 Preamplifier. A fully-balanced differential dual-mono design housed in 2 separate chassis, the P-8 is a masterpiece that produces absolutely no sonic colorations while loaded with numerous ergonomic features. This stupendous accomplishment is the result of a combination of extensive R&D yielding new proprietary technologies and the use of the very finest electronic parts available. To push the envelope even further, the MOON P-8 can be fully integrated into a custom-install environment and provides for a plethora of user selectable cosmetic options.
Significant Design Features:
  • Two chassis design with the larger chassis housing the power supply, digital controller circuitry, software processing and the LCD displays. The smaller chassis contains ONLY audio circuitry.
  • Full unsolicited RS-232 bidirectional feedback.
  • Custom proprietary toroidal transformer design with lower magnetic, electrical and thermal loss, yielding an improved power transfer and lower regulation factor. The result is increased current speed and better dynamics.
  • An oversized power supply with 6 stages of DC voltage regulation and choke filtering.
  • M-Ray volume control circuit based on the R-2R resistor array configuration that uses metal film surface mount resistors with 0.1% tolerances. The result is no sonic degradation of the audio signal regardless of the selected volume setting.
  • M-Lock circuit for “user selectable” maximum volume setting lock-out for each line input.
  • Power supply voltage regulation includes I2DCf (Independent Inductive DC Filtering); 1 inductor for each and every chip (i.e. OpAmp, DAC, Digital Filter, etc.) in the audio circuit’s signal path — 36 stages in all.
  • C4 Aesthetics: 24 end-user selectable cosmetics combinations: the MOON Logo can be chrome (standard), gold or pewter; leg cones can be chrome (standard) or gold; Front panel cheeks can be silver (standard) or black; Brushed/Anodized front face-plate can be silver or black.
  • Individual “gain offset” for each individual line input with a ±10dB range.
  • Each line input is fully configurable to be “home-theater ready”, where the gain section of the P-8 is bypassed.
  • Open-loop, zero-feedback circuit topology using absolutely no capacitors anywhere in the audio signal path.
  • Four-layer PCB tracings; 1 on top for ground plane, 1 on the bottom for power circuitry and 2 in middle for the audio signals. The advantages include better ground and power supply circuit layouts resulting in a much shorter signal path and dramatically improved signal-to-noise ratio.
  • Extremely rigid chassis construction to minimize the effects of external vibrations.
  • Accurate matching of the very finest quality electronic components in a symmetrical circuit design.
The MOON P-8 will have an MSRP of $9,500.00 USD.
Scheduled date of availability – February 2005
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
MOON by Simaudio's NORTH Series offers a completely new approach to high-end network streamers/DACs and power amplifiers.
MOON by SimAudio's 250i v2 Integrated Amplifier now represents the entry point into their award-winning range of components.
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it...
Your turntable may not sound great without the right phono preamp. Our Editors' Choice 2022 Phono Preamplifier options offer great performance for the money.
FOR IMMEDIATE RELEASE – August 26, 2004 Simaudio Ltd. proudly announces the introduction of the new MOON Calypso DVD Transport/Player, our newest addition to...
CD Players
Simaudio Ltd. proudly introduces the MOON Andromeda CD Player. A fully-balanced differential design housed in two separate chassis, the Andromeda represents an “all-out assault”...
Simaudio Ltd. proudly introduces the MOON W-8 Amplifier. A balanced differential dual-mono design, the W-8 is capable of driving virtually any loudspeaker to its...
