CD Players
Simaudio launches the MOON Andromeda Reference Differential CD Player
Simaudio Ltd. proudly introduces the MOON Andromeda CD Player. A fully-balanced differential design housed in two separate chassis, the Andromeda represents an “all-out assault” on the CD Red Book digital standard, producing a level of sonic performance with no equal. Quite simply, the MOON Andromeda raises the bar to previously unattainable levels. This colossal achievement is the result of a combination of extensive R&D yielding new proprietary technologies and the use of the very finest electronic parts available. To push the envelope even further, the MOON Andromeda can be fully integrated into a custom-install environment and provides for a plethora of user selectable cosmetic options.
Significant Design Features:
  • Internal 24-bit/352.8kHz upsampling using BurrBrown DF1704 Digital Filter with 8X oversampling.
  • Four precision-matched 24-bit BurrBrown PCM1704U-K “Digital To Analog” converters.
  • Full unsolicited RS-232 bidirectional feedback.
  • Digital input for use as a digital-to-analog converter with either a digital music server or external transport.
  • Custom proprietary toroidal transformer design with lower magnetic, electrical and thermal loss, yielding an improved power transfer and lower regulation factor. The result is increased current speed and better dynamics.
  • Separate digital and analog power supplies housed in an external chassis.
  • Philips CD-Pro 2-M transport mechanism mounted on our new gel-based Delta suspension.
  • Alpha Clocking Circuit with PLL synchronization yielding a very precise 5PPM digital clocking circuit.
  • Power supply voltage regulation includes I2DCf (Independent Inductive DC Filtering); 1 inductor for each and every chip (i.e. OpAmp, DAC, Digital Filter, etc.) in the audio circuit’s signal path — 56 stages in all.
  • C4 Aesthetics: 24 end-user selectable cosmetics combinations: the MOON Logo can be chrome (standard), gold or pewter; leg cones can be chrome (standard) or gold; Front panel cheeks can be silver (standard) or black; Brushed/Anodized front face-plate can be silver or black.
  • Top loading drawer with custom design disc clamping system for improved stability and long term reliability.
  • A capacitor-free signal path using a DC servo circuit and proprietary 6db/octave analog filter.
  • Four-layer PCB tracings; 1 on top for ground plane, 1 on the bottom for power circuitry and 2 in middle for the audio signals. The advantages include better ground and power supply circuit layouts resulting in a much shorter signal path and dramatically improved signal-to-noise ratio.
  • Extremely rigid chassis construction to minimize the effects of external vibrations.
  • Accurate matching of the very finest quality electronic components in a symmetrical circuit design.
The MOON Andromeda will have an MSRP of $9,800.00 USD.
Scheduled date of availability – February 2005
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
MOON by Simaudio's NORTH Series offers a completely new approach to high-end network streamers/DACs and power amplifiers.
MOON by SimAudio's 250i v2 Integrated Amplifier now represents the entry point into their award-winning range of components.
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it...
Your turntable may not sound great without the right phono preamp. Our Editors' Choice 2022 Phono Preamplifier options offer great performance for the money.
FOR IMMEDIATE RELEASE – August 26, 2004 Simaudio Ltd. proudly announces the introduction of the new MOON Calypso DVD Transport/Player, our newest addition to...
Simaudio Ltd. proudly introduces the MOON P-8 Preamplifier. A fully-balanced differential dual-mono design housed in 2 separate chassis, the P-8 is a masterpiece that...
Simaudio Ltd. proudly introduces the MOON W-8 Amplifier. A balanced differential dual-mono design, the W-8 is capable of driving virtually any loudspeaker to its...
