Simaudio 650D and 750D DAC/CD Transports Upgraded
Simaudio has added the MOON High-Resolution USB Interface for “Bit Perfect” USB Performance with 24-bit/192kHz data on their 650D and 750D DAC/CD Transports.
This interface is achieved with a new digital input board using the highly regarded XMOS XS1 microprocessor as an input receiver, allowing for fully asynchronous data communication. All MOON 650D's and 750D's manufactured from this point forward will be equipped this High-Resolution USB interface. For units manufactured prior to November 2011, a straightforward in-the-field upgrade path can be performed by an authorized MOON retailer or distributor; This entails a simple PCB swap which requires no soldering or firmware updates — the new board uses all existing mounting hardware and connectors.
Besides the increased bit-depth and sampling rate for USB data input, several design enhancements have led to an overall improvement in the sonic performance of the S/PDIF, AES/EBU and optical digital inputs. Effective immediately, MOON Evolution Series 650D and 750D DAC/CD Transports will now accept data streams up to, and including, 24-bit/192kHz on all digital inputs.
Significant Design Features
  • USB 2.0 audio interface using the XMOS XS1-L1 event driven microprocessor for bit perfect audio data up to 24-bit/192kHz with fully asynchronous clocking to help achieve virtually non-existent jitter
  • Supports sampling rates of 44.1, 48.0, 88.2, 96, 176.4 and 192kHz with bit depths from 16 to 24
  • Simple in-the-field upgrade path for MOON 650D's and 750D's manufactured prior to November 2011
  • Native support for MAC OS-X and Linux based computers (no device driver requried)
  • Easy to install Thesycon driver available at simaudio.com for Windows 7, Vista & XP based computers.
Pricing
  • The MOON 750D with High-Resolution USB → $13,000
  • The MOON 650D with High-Resolution USB → $9,000
Existing MOON 650D's & 750D's can be upgraded to High-Resolution USB for $1,000.00 USD
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
MOON by Simaudio's NORTH Series offers a completely new approach to high-end network streamers/DACs and power amplifiers.
MOON by SimAudio's 250i v2 Integrated Amplifier now represents the entry point into their award-winning range of components.
Simaudio is well-known for its audio components, but the Moon Voice 22 is its first entry into the loudspeaker category. Find out what it...
Your turntable may not sound great without the right phono preamp. Our Editors' Choice 2022 Phono Preamplifier options offer great performance for the money.
FOR IMMEDIATE RELEASE – August 26, 2004 Simaudio Ltd. proudly announces the introduction of the new MOON Calypso DVD Transport/Player, our newest addition to...
Simaudio Ltd. proudly introduces the MOON P-8 Preamplifier. A fully-balanced differential dual-mono design housed in 2 separate chassis, the P-8 is a masterpiece that...
CD Players
Simaudio Ltd. proudly introduces the MOON Andromeda CD Player. A fully-balanced differential design housed in two separate chassis, the Andromeda represents an “all-out assault”...
