SIM2 TEATRO 80 DLP Projector
SIM2 announced the Grand Cinema TEATRO 80 projector, an ultra high-end, highest brightness digital DLP projector. The TEATRO 80 uses three 0.95″ DarkChip4 DMDs to generate a picture resolution of 1920 x 1080 pixels (1080p). It is equipped with a renewed optical system that coupled with SIM2's dual-lamp system, delivers a superior contrast ratio of over 7,000:1 and a brightness of 4500 Ansi Lumens for crystal-clear, uncompressed HDTV images.
The finest quality precision glass optics are used throughout the light engine of the TEATRO 80; the clarity, color-uniformity and edge-to-edge focus capabilities of these specialized optical components are vital to the process of producing the breathtaking clarity of on-screen images.
SIM2 offers six Super High Contrast (SHC) lens options for the TEATRO 80, ranging from fixed short-throw wide-angle (0.67:1) through to long-throw (4.16-6.96:1).
Motorized zoom, focus, and lens shift (vertical and horizontal) complete the package. As befits an ultra-high end projector, TEATRO 80 is equipped with the Professional SIM2's EasyCinema software, a PC-based calibration system, featuring full seven-point adjustment of Primary, Secondary and White Point and full projector setup controls, allowing pin-point accurate calibration of the projector in any home theater or professional system.
The TEATRO 80 can be connected to a wide selection of video sources via its comprehensive input panel: six pure digital HDCP-HDMI inputs, an array of analog inputs, and professional format digital SDI input. A dedicated 10/100 Mbit Ethernet connector is fitted as standard, allowing the TEATRO 80 to be connected to a LAN network or to the internet. This network connection can be used to remotely control the projector using TCP/IP commands or to feedback projector operating status information.
Features
  • 3x 0.95″ 1080p DLP® DarkChip4 by Texas Instrument
  • 1920 x 1080 pixels HDTV resolution
  • Contrast ratio 7000:1
  • Brightness: 4500 Lumens
  • Lamp: 2 x 300W
  • Choice of 6 lenses
  • SIM2 EasyCinema software
  • 6 HDMI HDCP inputs (vers. 1.3 with DeepColor)
  • SDI professional input
  • Ethernet connection (IP addressable)
  • Vertical and horizontal motorized lens shift
  • 10-bit video processing
Pricing and availability has not yet been announced.
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
