SIM2 Sirio 3D DLP Projector Announced
SIM2 Sirio Projector
SIM2 announced a high-brightness, 3D active single-chip DLP-based projector for large media rooms or home theaters that have lots of ambient light. The new Sirio projector is powered by a dual 350W lamp system that delivers images with both very high brightness (up to 6,000 ANSI lumens) and high contrast (up to 6,000:1) without the screen reflection typical of flat panels.
Sirio is available with a choice of two different SIM2 color wheel options—SIM2color and SIM2shine, each designed to offer optimal performance in color and/or brightness.
Sirio sports PureMovie, PureAction, and PureAction 3D user modes, and SIM2’s advanced Live Colors, Calibration 2.0 software. An extensive array of connection possibilities is available including: HDMI 1.4 and LAN inputs. Systems integration is another of the SIRIO strengths; it will integrate seamlessly into any room thanks to a choice of 5 lenses available.
Sirio’s connection options include a RJ-45 connector (Ethernet or LAN) and a USB port hosting a dedicated USB-Wireless adapter. These control ports allow:
  • easy integration with Home Automation control systems that use IP addressable control;
  • Projector control by IP and;
  • remote monitoring and serviceability.
Price and Availability
Sirio by SIM2 will be available January 2013 for $28,000 in matte black finish.
Specifications:
DISPLAY
Technology: single-chip DMD
Resolution: Full-HD – 1920 x 1080 pixels
Light source: 2 x 350W UHP lamp
3D features and SIM2’s PureAction 2D/3D and PureMovie 2D technologies
DynamicBlack Technology enchanced solution BrilliantColor Technology
Color Wheel options: SIM2Color (optional); SIM2Shine (standard)
Contrast ratio (Full ON/ Full OFF): >6,000:1
Brightness:
– up to 4,500 Ansi Lumens (with SIM2Color);
– up to 6,000 Ansi Lumens (with SIM2 Shine)
INPUTS/OUTPUTS
2x HDMI (v.1.4 with Deep Color)
1x Composite Video (RCA)
1x Graphic RGBHV (D-sub HD15 pins)
1x RS-232 (D-sub 9 pins)
1x USB (A type) socket for USB to Wi-Fi adapter 1x LAN (RJ45 ethernet port)
3D Sync Out
3x 12V 100mA output
INSTALLATION
Lens options (throw ratio): 1.45-1.93:1 (standard); 0.77:1; 1.21-1.45:1; 1.93-3.67:1; 3.67-6.97:1 (optional)
Optical shift: Motorized with memory, Vertical up to +60%, down -20% max. from screen center (based on image height), horizontal +/-10%
Digital Keystone: Vertical
Picture size (inches diagonal): 50-300
Aspect ratio: 4:3, 16:9, Anamorphic, Letterbox, Panoramic, pixel-to-pixel, subtitle + 3 custom-user adjustments
ELECTRONICS AND CONNECTIVITY
Horizontal & Vertical scan freq.: 15-80 kHz/48-120 Hz
Color System: PAL (B,G,H,I,M,N,60); SECAM; NTSC 3.58; NTSC 4.43;
PC graphic standards and HDTV: VGA, SVGA, XGA,SXGA, UXGA, WUXGA; SDTV: 480i/p, 576i/p; HDTV: 720p 50/60, 1080i 50/60, 1080p 24/50/60 + 576p
GENERAL SPECIFICATIONS
Software control: upgradable via RS-232 serial interface, USB or LAN
Power supply: 100-240 VAC +/-10% (48/62 Hz)
Power consumption: 1100W
Projector weight: 28 kg. / 62 lbs
Projector dimensions (WxHxD): 464 x 241 x 564 mm (18.3 x 9.5” x 22.2”)
3 Comments
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
