SIM2 C3X LUMIS HOST Projector System
Reference standard three-chip projection is now available with long distance connectivity.
SIM2, the Italian manufacturer whose striking high-performance HD home theater projectors are known worldwide for their pristine video and dramatic cabinet designs, delivers a new addition to the award-winning the Grand Cinema C3X Series. SIM2’s C3X LUMIS HOST pairs a reference standard 3-chip DLP -based projector with a discrete outboard projector control electronics module that connects via SIM2’s proprietary, three-line optical-digital High-Definition Optical Signal Transfer (H.O.S.T.) system, which is able to connect the two over distances up to 750 feet (250m).
“The C3X 1080 is considered the projector of choice when it comes to benchmark three-chip DLP performance in a compact yet elegant chassis. The C3X LUMIS HOST system is a natural evolution for the C3X 1080 Series,” said Charlie Boornazian, VP of SIM2 USA. “We are now offering a three-chip solution that blends the beauty of the C3X series with the brains of a modular processor system. The ability to separate the projector from its control electronics by fiber-optic cable with a loss-less connection, allows our dealers the ultimate flexibility of installation. The HOST system proved to be wildly popular for our single chip offering the HT3000E – and by completing the package with a three-chip reference design glamour goes modular the SIM2 way!”
The C3X LUMIS HOST is based on a trio of the latest 0.95-inch, 1080p DLP chipsets from Texas Instruments, whose next-generation DarkChip4™ DLP device yields an important increase in picture quality with improved blacks and superior brightness when partnered with SIM2’s proprietary ALPHAPATH™ light engine. This powerful combination forms a system that delivers full-HD, 1920×1080 progressive video of stunning clarity and definition. The projector’s superb contrast ratio (>35,000:1) is matched by its impressive color depth and remarkable light output (3000 ANSI lumens), resulting in images that have an incredibly realistic, almost three-dimensional quality to them!
An important new feature for the C3X LUMIS HOST is SIM2’s light intensity control system, which in essence, increases the projector’s contrast ratio to >35,000:1 through the use of three separate specialized components: a user adjustable iris, DynamicBlack™ technology and a new dimmable lamp. However, unlike other variable iris systems which can inflict detrimental effects on the final picture, SIM2’s custom-designed system provides micro-second precision-matched light intensity adjustment to the source material, on a frame-by-frame basis. The resulting black level and shadow detail add a new sense of realism to the image. This is yet another example of how SIM2’s R&D expertise enables the company to push the performance envelope for projection beyond the capabilities of other manufacturers.
The SIM2 HOST module is a discrete, compact component (approx. 14 x 4 x 12-inches) designed for flexible placement, thanks to SIM2’s HOST three-line digital fiber-optic connection, which empowers A/V installers to locate it up to an astonishing 750 feet from the projector and is impervious to electrical interference – even when placed in conduit containing high voltage electrical cables. This capability creates an entire range of previously unavailable installation options and more importantly, eliminates the usual signal losses and electrical interference pick up associated with long cable runs. The HOST module incorporates superbly flexible video switching with no less than six HDCP-compliant HDMI inputs, three HD-capable component-video inputs, and multiple legacy composite and S-video inputs as well as RGB and the SDI professional format. Add to this, the wide choice of control options on offer: IR, RS232 and IP addressable, and C3X LUMIS HOST becomes a very potent proposition for installers and customers alike.
The C3X LUMIS HOST delivers supreme performance, design and flexibility of installation. A dedicated 10/100 Mbit Ethernet connector is fitted as standard, allowing the product to be connected to a LAN network or to the internet. This network connection can be used to remotely control the projector using TCP/IP commands or to feedback projector operating status information such as: serial number, working hours and firmware version to a designated e-mail address for assessment.
Grand Cinema™ C3X LUMIS HOST can be easily configured to meet the exacting requirements of a wide range of home theatre and professional applications, optimising light intensity and black level to each scenario. Whether the requirement is for high brightness (3000 Ansi Lumens) or optimum black level in darkened conditions, C3X LUMIS HOST offers unrivalled customization and flexibility.
In the best SIM2 tradition, the C3X LUMIS HOST is housed in a stunning, high-gloss sculpted cabinet designed by Giorgio Revoldini with the company’s trademark, flowing lines — an Italian masterpiece!
C3X LUMIS HOST — modular, by design.
Availability: December 2008
Finish Options: High-gloss black/silver
Suggested Retail Price:
$36,495 (with T1 short-throw or T2 long-throw lens)
$37,995 (with T3 extra-long throw lens)
About SIM2 USA Inc. and SIM2 Multimedia
Since their entrance into the US home theater market in 1999, SIM2 USA, under the guidance of its parent SIM2 Multimedia (established in 1995), has dedicated its resources to marketing and servicing products that meet the demands of the US market. SIM2 Multimedia is a worldwide leading manufacturer of home theater products and leading provider of high-end performance large screen systems (for control rooms, information, communication, and simulation) and professional projection systems for E–cinema applications. Over the years, SIM2 has gained a reputation for meeting the industry’s demands for new, emerging technologies, offering high-quality and reliable products that meet the customer’s need in any application. Products are designed and manufactured in Italy. The marketing policies of the company are world-oriented, with a direct presence in Italy (headquarters), the USA, UK, China, Germany (sister companies), and in over 60 countries worldwide through partnerships with qualified distributors. For more information, please visit www.SIM2USA.com.
Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
