Shuttle X350 Slim Mini PC
The smallest and slimmest PC in its class
The Shuttle X350 slim mini PC is available for U.S. pre-order starting at $399.00. The ultra-compact Shuttle X350 is a mere 1.5 inches thin and packs in a dual-core Intel® Atom D510 processor, on-board Intel® graphics or next generation NVIDIA® ION graphics with true 1080p HDMI output (optional), and slim optical drive bay for your choice of DVD drive (optional).
“We're really pushing the envelope as to what can be packed inside this tiny box we call the X350 or XS35 that's only about the size of an external hard drive,” said Nicolas Villalobos, Director at Shuttle Computer Group in Los Angeles. “It's perfect for everything from living room entertainment to digital signage, healthcare, and point -of-sale (POS) applications. It's even powerful enough for Blu-ray, though we do not officially have the option just yet.”
The X50's slim design is not only space-saving for projects or applications where space is critical, but it fits easily into any environment with the ability to be mounted behind an LCD TV or LCD monitor. It's also completely fanless. The internal layout has been meticulously engineered to require no fan, so it's not only quiet and low in energy consumption, but it's also dust-free and virtually maintenance free.
Features
  • Power Packing Graphics
    Even with the small size, the new X350 packs in a slim optical drive bay and the next-generation NVIDIA® ION graphics with true 1080p HDMI output (optional) for a power-packing slim PC that's unmatchable in size and performance — and is made for more than just entertainment.
  • Fanless Design
    Completely fanless — by design — the internal layout has been meticulously engineered to require no fan, so it's not only quiet and low in energy use, but also dust-free and virtually maintenance free.
  • VESA
    The X350 is slim, small, and can be placed virtually anywhere. It can even be wall mounted or fitted behind your monitor with the available VESA mounting bracket (optional).
  • *VESA (Video Electronics Standards Association) was established in 1989 to set and support industry-wide interface standards designed for the PC, workstation, and other computing environments.
  • 4-in-1 Card Reader
    The built-in 4-in-1 card reader makes it easy to transfer files from your camera so you can share videos and photos on you X350 with ease.
  • Realistic Audio
    Enjoying movies, videos, photos, and music stored on your X350 is simpler than ever. The on-board audio makes it easy to plug in just one wire to bring the ultimate entertainment experience home.
  • Built-in Wi-Fi
    High-speed 802.11n wireless technology is built into Shuttle X350. You can print, surf the web, and even download music wirelessly.
Specifications
OPERATING SYSTEM Microsoft Windows® 7
PROCESSOR Intel® Atom D510 Dual Core 1.66GHz
MEMORY 1GB DDR2 (Up to 2GB)
CHIPSET Intel NM10 Express Chipset
STORAGE 160GB SATA 2.5″ HDD (Up to 500GB)
CARD READER Integrated 4-IN-1 Card Reader (SD/MMC/MS/XD)
GRAPHIC CARD Integrated Intel GMA 3150 (With VGA Output) / Nvidia ION2 w/ X350 Ion Model
OPTICAL DRIVE DVD Super-Multi writer drive SATA 12.7 height
NETWORK 802.11b/g/n (Built-In Wireless)
10MB/s,100MB/s,1GB/s
POWER External 40W fanless power supply
FRONT PANEL
  • Power-on Button
  • 4 in 1 Card Reader
  • 1 x USB port
BACK PANEL
  • 1 x D-sub Port
  • 1 x HDMI (ION 2 Model)
  • 4 x USB Port
  • Microphone input
  • Head Phone Output (Line-out)
  • LAN
  • WLAN 802.11 b/g/n
  • VGA
  • HDMI (Optional ION 2 Model)
  • Kensington lock
  • DC-input for Power Supply
DIMENSION (W) 1.5 x (H) 6.4 x (D) 9.9 Inches
Optional: VESA 75/100 mounting kit
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
