Shut down computers automatically at schedule time and save electricity
GoldSolution Software announces the release of PC Auto Shutdown 3.68, a handy utility for the Windows operating system that helps users shut down computers automatically at schedule time and save precious electricity.
A typical PC left on for 24 hours each day can use $70 or more of energy per year. If a computer is turned off at every night and weekends, it will only use around $20 of energy per year. Power outages have happened in the world , from United States to Europe, therefore power saving is important for every computer user.
PC Auto Shutdown can shut down, hibernate, suspend, log off and reboot computers automatically at schedule time and save power. It is easy to use, just set up the timer you want to shut down, and it will work silently at background until the timer comes. If a user doesn’t want to do shutdown events at specified time, it is easy to abort it.
PC Auto Shutdown can activate computers from hibernation mode at schedule time and shut it down. What’s more, it can shut down computers automatically when no user is logged in. During shutdown, it can clean up Recycle Bin, temporary files and Internet Explorer cache to improve system performance and protect privacy.
PC Auto Shutdown is the right choice for computers auto-shutdown and power conservation. It is both affordable to every computer user and a real value.
System Requirements
PC Auto Shutdown will run under Windows 98, Me, NT, 2000, XP, 2003 and Vista on an Intel-based 586 PC or greater. It supports 32-bit and 64-bit operating system. The program requires 16 MB of RAM and 2 MB disk space to install.
Price and Availability
PC Auto Shutdown is available now. The price for single user license is $19.95 USD. There are volume licenses with some discount for multi users. A trial version is available from the GoldSolution Software web site at:
http://www.drivermagician.com/autoshutdown/
EVALUATION COPIES ARE AVAILABLE ON REQUEST
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
