Monitors
Sharp PN-K321 IGZO LCD Monitor Announced
Sharp PN-K321
At CES 2013, Sharp is revealing its state of the art 32″ (31.5″ diagonal) class professional LCD monitors, the PN-K321 and a touchscreen monitor prototype, which feature IGZO technology with ultra-high-definition 4K × 2K resolution (3,840 × 2,160 pixels), four times the pixel resolution of full high definition. These models also boast the industry’s thinnest design at just 35mm. The touchscreen monitor prototype is capable of 10-point multi-touch option, allowing users to perform multiple gestures at once simply by touching the screen, which is especially useful for portraying and interfacing with images, graphics, complex visual elements or architectural designs.
Featuring much smaller thin-film transistors (TFTs) as compared to conventional displays, IGZO technology also significantly increases the amount of light transmitted per pixel. As a result, these advanced displays portray vibrant and crisp content with the ability to zoom in to examine the detail of a picture or text, or pan out to view content from a wider angle. This can help boost operational efficiency and reduce eyestrain by sparing users the need to scroll frequently.
Sharp PN-K321 - verticalCombining Sharp’s IGZO technology with a brilliant white, edge lit LED backlight system, these state-of-the-art monitors measure only 35 millimeters at their thickest point (that’s less than an inch and a half), making them the industry’s thinnest design in their class.
Sharp says it is the first company to successfully mass produce IGZO (Indium Gallium Zinc Oxide), an innovative compound that replaces the industry standard amorphous silicon material used for the active layer in thin-film transistors (TFTs). IGZO has the potential engender a whole generation of display products that produce high resolution images, are dramatically more energy efficient and are ultra-responsive to touch.
IGZO’s advantages are:
  • Super high resolution and clarity: IGZO’s transistors are much smaller than traditional LCDs thanks to significantly higher electron mobility. Therefore, more data can be shown in a single display, creating a stunningly detailed image – up to four times that of conventional full-HD or 1080p LCDs.
  • Ultra low power consumption: IGZO can maintain the onscreen data for a certain period of time without refreshing the data, even when the current is off. This helps cut back the power consumption to achieve longer battery life for mobile displays.
  • High performance touch response: Compared to conventional LCDs, IGZO displays have drastically minimized the noise caused during touch input. This allows for quick, easy, more natural-feeling writing and smooth lines.
Additionally, the series is outfitted with two HDMI ports and one DisplayPort interface which are both capable of using a single connector cable in order to transmit an ultra high resolution signal, helping to simplify cable management and reduce desktop clutter. Backed by Sharp’s 3-year limited warranty, both models support landscape and portrait orientation and are designed for 24/7 operation.
Price and Availability
The Sharp PN-K321 (non-touch model) is planned to launch in February 2013, with the touch model soon to follow.
[youtube id=”SnUUXoFsjoY” width=”610″ height=”373″]
2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
