Monitors
Sharp Introduces 65-inch LCD PN-655 HD Monitor
The World’s Largest*1 Full-Spec High-Definition Commercial Monitor Offers Crisp, Detailed Image Presentation and Unparalleled Videoconference Imagery
Sharp will introduce into the Japanese market the PN-655 LCD Monitor made at the Kameyama Plant, which uses a 65V-inch full-spec high-definition LCD panel (resolution of 1,920×1,080 pixels).
The large 65V-inch screen brings images to life with its pure size. It also faithfully reproduces computer-generated images such as CAD data with impressively high-resolution and high quality right down to the finest details. And because it’s LCD, the PN-655 gives expressively colored images even in bright rooms and allows everyone in a meeting, no matter where they are sitting, to see the information on-screen with equal clarity. The high-definition videoconference function displays facial expressions with detail, so smooth, clear communication is possible wherever in the world you are. A wide range of interfaces means a wide range of networking possibilities, making the PN-655 a new, all-purpose business solution.
By commercializing large-screen, full-spec high-definition information monitors that reproduce high-resolution, high-quality images, Sharp will continue to establish LCD superiority in the commercial monitor market.
Product name LCD Monitor
Model name PN-655
Suggested retail price Open
Date of introduction in Japan March 24, 2006
Major Features
1. A 65V-inch high-resolution, full-spec high-definition LCD panel (resolution of 1,920 H x 1,080 V pixels) faithfully reproduces high-definition, high-quality digital images for CAD data and videoconferencing
2. Employs a “dual fine engine,” which enables the display of both PC digital data and audio-visual images in full-spec high-definition.
3. Uses “picture in picture” and “picture by picture” functions to display various image sources simultaneously.
4. Strengthened functions for commercial use, such as a fanless design, remote control functions, and capability of around the clock operations.
Specifications
LCD panel 65V-inch wide (163.9 cm diagonal) Advanced Super View low-reflection black TFT LCD
Dot count 1,920 H x 1,080 V pixels
Max. colors 16,770,000 colors (8 bit/color)
Screen brightness 400 cd/m2
Contrast ratio 700:1
Viewing angle Vertical: 170°, horizontal 170° (CR10)
Screen size 1,428 H x 804 V mm
Computer input signal
Video signal Analog RGB (0.7Vp-p) [75 ohm], digital (DVI 1.0 standard-compliant)
Sync signal Horizontal/vertical separate (TTL: positive/negative), Sync-on-green, Composite sync (TTL: positive/negative)
Video signal system NTSC (3.58MHz)
Functions
Plug and play VESA DDC2B
Power management VESA DPMS, DVI DMPM
Automatic screen adjustment Clock, phase, automatic screen adjustment (horizontal/vertical)
Automatic gain control Black level, contrast
Screen enlargement Digital scaling (revise and enlarge VGA, SVGA, XGA, SXGA screens to 1,920H x 1,080V)
User adjustment Clock, phase, screen adjustment (horizontal/vertical), black level, contrast, brightness, OSD
Color temperature (5 preset modes or user settings),display modes (including office mode)
Sleep timer 1 to 23 hours
Reset all Restores all settings to factory defaults
Screen reset Restores screen settings to factory defaults
Lock function Lock settings to prevent adjustments
PinP, PbyP PinP: displays picture-in-picture PbyP: displays split screen
Input terminals*2
Computer signal Digital: DVI-D 24 pin (1 line)
Analog: Mini D-sub 15 pin (1 line)
Computer audio o 3.5 mm mini stereo jack (1 line)
RS-232C D-sub 9 pin (1 line)
Composite video BNC (1 line)
Component BNC (Y, Cb/Pb, Cr/Pr) (1 line)
D4 video D terminal (1 line)
Audio RCA pin (L/R) (1 line)
Output terminals*2
Computer signal DVI-D (1 line)
Speaker 10W + 10W (6Ω)
Wall mount bracket Four screws (650-mm pitch, 440-mm width) (M10 screws)
Power requirement 100V AC, 50/60Hz
Power consumption 550W
Operating temperature 0°C to 40°C
Operating humidity 20% to 80% (no condensation)
Dimensions (display) Approx. 1,572 (W) x 126 (D) x 923 (H) mm (excluding protrusions)
Weight Approx. 65 kg (excluding stand)
Dimensions/weight when packed Approx. 1,720 (W) x 575 (D) x 1,290 (H) mm (Approx. 99 kg)
Accessories AC power cord (2 pin + ground cord) (Approx. 4m), remote control, AA battery for remote control (2), CD-ROM utility, operation manual, warranty
Regulatory approvals VCCI class A, PSE
*1 As of February 16, 2006, for commercial-use LCD monitors.
*2 Uses commercially available connection cables for PC connections and imaging equipment.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
