Shanling EH2 DAC/Headphone Amplifier To Make Its Debut at CanJam NYC 2025
Forte Distribution previews Shanling’s $399 EH2 DAC Headphone Amp for CanJam Attendees
Shanling EH2 Headphone Amplifier and DAC
Shanling is not a well-known audio brand in the U.S., but we have reported on several of their products that have been well-received, including the CR60 CD Transport and Ripper, SM1.3 Streamer, HW600 Headphones, and BA1 Hi-res Bluetooth Adapter.
As a follow-up to those components, Forte Distribution is showing the Shanling EH2 Desktop DAC/Headphone Amplifier at CanJam NYC 2025 (February 22-23) in conjunction with making it available to dealers and consumers in the U.S.
The EH2 (SRP: $399) is a sleek, stylish, compact model that is designed to perform well above its price class, with power and sonic detail to spare.
From  Roger Fortier, VP and Director of Sales, Forte Distribution, U.S. distributor of Shanling Electronics: “Desktop DAC/amplifiers are a great way to turn computers and portable players into true high fidelity sources, but consumers are often forced to choose between performance and affordability,…But with the EH2, our team created the perfect high-fidelity/high-value hybrid with advanced technology and a price tag that is within reach of nearly every music lover with a pair of high-end headphones.”
Shanling EH2 Desktop DAC Headphone Front
Designed by Shangling’s in-house engineering team, the EH2 features a 24-bit R2R DAC that follows in the footsteps of previous high-performance/high-value models that are based on Burr Brown PCM1704 DACs.
The EH2 has the power output to run any set of headphones, with up to 24.3W @ 32 ohms via its 4.4mm balanced output, and 1.3W @ 32 ohms via its single-ended 6.35mm output.
Adding to the flexibility of the EH2 is an additional circuit for RCA & 4.4mm Line-out /Pre-out, based around the OPA1612 amplifier and its low noise/low distortion characteristics, providing pure R2R output to active speakers and power amplifiers.
As a further upgrade to the previously released EH1, the new EH2 includes the XMOS XU316 module for its USB input and Qualcomm QCC5125 chip which Bluetooth 5.2, ensures maximum connectivity with high-resolution LDAC and aptX codecs. Other additions to the EH2 include both digital optical and digital coaxial audio inputs.
Two headphone outputs are  provided — 4.4mm and 6.35mm — that are placed on the front, as are volume, tone, gain, and source controls
Shanling EH2 and EH1 Comparison
Shanling EH2 vs. EH1
ModelShanling EH2 (2025)Shanling EH1 (2024)
Product TypeDAC/Headphone AmpDAC/Headphone Amp
Price$399.00$229.00
Hi-Res Audio SupportUSB: 768kHz/32-bit, DSD 512USB: 768kHz/32-bit, DSD 512
InputsUSB-C, Coaxial, Optical, BluetoothUSB-C
Outputs 6.35mm & 4.4mm Headphone output, RCA & 4.4mm Line Output. 6.35mm & 4.4mm Headphone output, RCA  Line Output, Digital Coaxial
4.4mm Headphone Output Power:Low gain: 2365mW @ 32 ohms
High gain: 4351mW @ 32 ohms
Low Gain: 250mW@32ohms
High Gain: 980mW@ohms
4.4mm Headphone Output  Frequency Response20HZ-40KHZ (-0.5dB)   20Hz-40kHz (-0.5dB)
4.4mm Headphone Output  THD + N0.02% @ 32 ohms0.008% (A-Weight@1Vrms High Gain@32Ω)
4.4mm Headphone Output Dynamic Range118DB @ 32 ohms119dB
4.4mm Headphone Output Channel Separation111dB @ 32 ohms99dB
4.4mm Headphone Output Signal-to-noise Ratio 118DB @ 32 ohms119dB (A-Weight High Gain)
4.4mm Headphone Output Output Impedance<2 Ohm  0.8Ohms
6.35mm Headphone Output PowerLow Gain: 632mW @ 32 ohms
 High Gain: 1280mW @ 32 ohms
6.35mm Headphone Output  Frequency Response20HZ-40KHZ (-0.5dB)   20HZ-40KHZ (-0.5dB)
6.35mm Headphone Output  THD + N0.02% @ 32 ohms0.007% @ 32 ohms
6.35mm Headphone Output Dynamic Range117dB @ 32 ohms119dB @ 32 ohms
6.35mm Headphone Output Channel Separation74dB @ 32 ohms75dB @ 32 ohms
6.35mm Headphone Output Signal-to-noise Ratio 117dB @ 32 ohms119dB @ 32 ohms
6.35mm Headphone Output Output Impedance<1 ohm<0.4 ohm
Line OutRCA / 4.4mm RCA
Line Out Output Power2.2V / 4.5V2.38V
Line Out Frequency Response   20HZ-40KHZ (-0.5dB) 20Hz-40kHz (-1.2dB)
Line Out THD + N0.02% 0.0007% (A-Weight High Gain)
Line Out Channel Separation118 dB114 dB
Line Out Signal-to-noise ratio 119DB122dB
Dimensions156 x 150 x 36.5mm (6.14 x 5.9 x 1.44 inches)156 x 90 x 36.5mm (6.14 x 3.5 x 1.44 inches)
Weight713g (1 lb 9 oz)392.5g (14 oz)
Shanling EH2 Desktop DAC Headphone Amplifier
The Bottom Line
Shanling is slowly building a reputation for offering practical audio solutions at fairly reasonable prices. The EH2 adds additional connectivity over its predecessor, the EH1, which supports more user flexibility.
The physical appearance of the EH2 reminds us of something that might come from iFi, such as their ZEN CAN 3 and Zen Blue 3.
At $399, the EH2 is a lot less expensive than many offerings (refer to our Related Reading section for examples), but with some of the lower-priced desktop USB DAC/Headphone amps from Schiit Audio, iFi, FiiO, and Audioengine, the EH2 still faces some formidable competition.
Price & Availability
Forte Distribution is Now Shipping Shanling’s EH2 DAC/Headphone Amplifier for the U.S. Market at a price of $399 direct from Forte or from authorized dealers
The EH2 is also a part of Forte Distribution’s extensive display at CanJam NYC 2025 which also includes  Shanling’s CR60 CD transport and ripper, ET3 CD transport, SM1.3 streamer, M8T portable audio player, HW600 headphone, and, from Onix, the MX10 LTD portable player.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Does full EQ functionality and even more power make the Element IV an easy recommendation at $549?
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Smaller, lighter, and more affordable than the flagship Empyrean II, the $2,000 Meze Audio Poet have planar magnetic fans rather excited.
Headphones
Not only do the new Grado Signature S950 feature an improved headband, gorgeous ear cups, and a brand new 52mm driver...but they finally have...
At $1,999, Orchard Audio Valencia is a balanced desktop power amplifier designed for headphones, but powerful enough for speakers.
