Earbuds & In-Ear Headphones
Sennheiser’s TV Clear Set 2 Earbuds Might Save Your Marriage
Better ergonomics, improved sound quality, and better transmitter performance are just some of the improvements for the Sennheiser TV Clear Set 2 Wireless Earbuds.
Sennheiser TV Clear Set 2 Wireless Earbuds Lifestyle
In August 2022 Sennheiser announced its TV Clear True Wireless Earbuds. This provided an earbud option that was specifically tailored for TV viewers.
The original Sennheiser TV Clear provided a personal audio listening experience with independent volume and five speech clarity levels; whilst allowing others to watch the same program using the TV’s internal loudspeakers or a soundbar at the same time.
Enter the TV Clear Set 2
Sennheiser TV Clear Set 2 Wireless Earbuds with Charging Case
As good as the original TV Clear Set is, Sennheiser has decided to introduce the TV Clear Set 2 with improved sound quality, effortless setup, and smart customizations accessible via the companion app.
From Michael Eckardt, Senior Product Manager: “We listened to feedback from our passionate customers and went right to work. Our TV Clear Set 2 sounds better, sets up easier, and even fits better for a listening experience that builds on the success of the original. For TV and movie watchers who want to listen at a personal volume level while improving speech intelligibility, it’s our best true wireless big-screen companion yet.”
Retaining the great dialog enhancement and wireless freedom of the original model, the TV Clear Set 2 brings Sennheiser’s signature sound to your television and movie viewing experience.
Sennheiser TV Clear Set 2 Connector Black
New Features
Better Fit: Better sound arrives with a better fit, too, thanks to revised acoustic apertures and ear adapters that make finding the perfect fit an easier task—especially in smaller ears.
Transmitter Pre-Pairing: The TV Clear Set 2 comes pre-paired to its included transmitter. This means you can start using the Clear Set 2 with your TV (or other compatible audio source) right away.
Bandwidth: The transmission bandwidth has been doubled.
Updated Transmitter: The transmitter provides Dolby 5.1 compatibility when it’s connected via the TV’s S/PDIF digital audio outputs. In addition, the transmitter includes a USB-C power port.
Improved Control Buttons: The earbud buttons have been redesigned for easier volume adjustment and setting the Speech Clarity level.
Updated TV Clear Companion App: The TV Clear app is a free download and can be installed from the App Store (iOS and iPad OS) or Google Play Store (Android).  With the app users can further customize their TV Clear Set 2, including visualized volume control, double-tap gesture configuration, improved charging status feedback, and more.
Continued Features: The Clear Set 2 continues to provide convenient Qi wireless charging, multipoint connectivity to multiple devices, and up to 15 hours of listening per charge with another 1.5 charges in the case.
Sennheiser TV Clear Set 2 Wireless Earbuds with Charging Case Open
Specifications
Tip: The following specifications are the same as for the TV Clear Set One
  • Product Number: 119-3016-P810
  • Wearing Style: True Wireless Earbuds
  • Ear Coupling: Ear canal with retention
  • Transducer Type: Dynamic
  • Transducer Diameter: 6mm
  • Frequency Range: 20 Hz to 20 kHz
  • Speaker Sensitivity: 100.5 dB, SPL (1 kHz / 1 mW)
  • Total Harmonic Sistortion (THD): < 0.5% (1kHz/94dB)
  • Connectivity: Bluetooth 4.2. This allows wireless reception from the provided TV  transmitter as well as from other compatible Bluetooth source devices.
  • Modulation: 2400.0 MHz to 2483.5 MHz
  • Supported Bluetooth Profiles: A2DP (SBC), HFP (CVSD, mSBC), AVRCP, DID
  • Active Noise Cancellation: Passive damping with Ambient Awareness mode
  • Microphone Type: MEMS (for hands-free phone calling)
  • Microphone Frequency Response: 100 Hz to 10 kHz
  • Microphone Pick-up Pattern: 1 mic for Ambient Awareness mode; 2 mic beamforming during a call
  • Battery Time:  Up to 15 hrs streaming with TV Clear Transmitter 2; Up to 12 hrs streaming with A2DP; 1.5 additional charges through charging case: 5 min charge = 1hr additional streaming when empty
  • Charging Time: Approx. 2 hrs for a full charge; approx. 3 hrs for wireless Qi-Charging
  • Battery type: Built-in Lithium-Ion rechargeable batteries; left/right earbud: 69 mAh, charging case: 490mAh
  • Power Supply: 5 V⎓, 600 mA max, USB charging via USB-C socket at charging case; Qi Wireless charging
  • Dimensions: 23.0 x 18.0 x 26.0 mm (earbuds) / 87.8 x 47.5 x 29.2 mm (charging case)
  • Weight: 64 g (both earbuds and charging case) / 5.7 g (6.9 g with ear coupling) / 50.2 g (charging case)/ 34 g (transmitter)
Sennheiser TV Clear Set 2 Wireless Earbuds Accessories
What Comes in the Box
  • TV Clear Earbuds 2
  • Charging case
  • Ear adapter sets
  • TV transmitter
  • Connectivity cables
Availability and Pricing
TV Clear Set 2 is available for pre-order for $399.95 USD / $549.95 CAD and will be available for delivery in North America on June 12th, 2023.
1 Comment
1 Comment
  1. ORT
    May 23, 2023 at 3:43 pm
    Cool. I have been using (off and on) my Sennheiser RS195 ‘phones for several years now. I have tried IEMs but find them uncomfortable but Sennheiser does not make junque so I would think these babies are not going out with the bathwater.
    ORT
FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
WiiM Vibelink Amp Lifestyle WiiM Vibelink Amp Lifestyle
WiiM is well-known for its streaming products, but they are expanding their reach with a dedicated integrated amplifier.
Meze Audio POET Headphones on Table with Cable Meze Audio POET Headphones on Table with Cable
Smaller, lighter, and more affordable than the flagship Empyrean II, the $2,000 Meze Audio Poet have planar magnetic fans rather excited.
Grado Signature S950 Headphones on woman lifestyle Grado Signature S950 Headphones on woman lifestyle
Headphones
Not only do the new Grado Signature S950 feature an improved headband, gorgeous ear cups, and a brand new 52mm driver...but they finally have...
Burmester 232 Integrated Amplifier Front View Angle Burmester 232 Integrated Amplifier Front View Angle
Starting at $21,600, the high-end Burmester 232 Integrated Amplifier offers DAC and Phono pre-amp upgradability for $13,300 extra.
Wharfedale Aston Stand-mount Speakers Pair Wharfedale Aston Stand-mount Speakers Pair
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Super Bowl LIX Gift Guide
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
SonicEdge takes on XMEMS Labs in the micro-speaker category with its own innovations.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
At $449, the Noble Audio FoKus Rex5 wireless noise cancelling earbuds drop xMEMS support in favor of a new hybrid 5-driver array.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
