Sennheiser RS-5200 Wireless TV Headphones Arrive Just in Time for Hockey Season
The Sennheiser RS-5200 headphones may look odd, but might be a great solution for listening to TV without disturbing others. Check out the details.
Man wearing Sennheiser RS-5200 Wireless Headphones watching TV
It’s almost that time of year. Hockey season. Nothing annoys my family more than when I turn on a game and watch it in surround sound until almost 11 p.m. during the season. The Sennheiser RS-5200 Wireless TV Headphones might just save me from being cross-checked on the stairs this season.
Watching TV really early in the morning or late at night can be challenging as the sound may disturb others. If you turn your TV sound down too low it becomes difficult to hear the dialog. In some cases, you can turn on subtitles or closed captions, but that isn’t the same as getting the full sound impact of what you are watching.
Sennheiser RS-5200 Wireless Headphones with Charger
With that in mind, the Sennheiser RS-5200 wireless headphones allow you to listen to the sound of your favorite programs and movies with full impact without disturbing the other members of your household.
The Sennheiser RS-5200 consists of two pieces, the headphones, and the docking station.
The Headphones
The headphones feature a stethoscope design that reduces pressure on the temples and ears. It also provides added comfort for those that wear glasses. There is a master volume control on the headphones, and inside there is a built-in rechargeable battery.
Sennheiser RS-5200 Wireless Headphones with Ear Tips
Switchable ear tip adapters are also provided for better fit, which also enhances the listening experience.  The included ear tip adapters are:
  • Large and Small Silicone Pads – These accommodate different size ear canals.
  • Memory Foam – Provides ambient noise isolation. However, the memory effect of the foam wears off after a few months of steady use.
  • Open Foam – This option is designed for those with pressure-sensitive ears and is comfortable over long listening times.
The Docking Station
Sennheiser RS-5200 Wireless Headphones on Table in Charger
The other part of the RS-5200 package is the included docking station.  The Docking Station has four functions:
1. Charger for the RS-5200 Headphones
2. Connects to your TV’s digital optical or analog audio/headphone outputs. Depending on the brand/model TV, you may have to activate digital optical/3.5mm/RCA analog audio outputs. Also, make sure your TV audio is set to PCM audio output.
3. Transmits the signals received from the TV via the connection cables to the headphones using the 2.4 GHz band.
4. Serves as the settings control center for the headphones. The setting options include:
  • Three hearing profiles (EQ settings).
  • Speech Clarity/Active Noise Cancelling setting.
  • In addition to the master volume control on the headphones, the docking station also has independent Left and Right channel volume controls to optimize ear balance.
Sennheiser RS-5200 Wireless Headphones Closeup of Controls
Core Specifications
Speaker typeDynamic with neodymium magnets
Frequency response15 – 16,000 Hz
Sound pressure level (SPL)Max. 125 dB at 1 kHz, 3% THD
THD, total harmonic distortion<0.5% at 1kHz, 100dB SPL
Transmission Frequency Band2.4 GHz
Transmission/Reception RangeUp to 70 meters or  200 ft
Charging Time Up to 3 hours
Playback Battery Time (there is a charging reminder)Up to 12 hours
Warranty2 years
Sennheiser RS-5200 Wireless Headphones on Magazine
What’s in the Box
  • RR 5200 headphones with built-in rechargeable battery
  • TR 5000 transmitter and docking station
  • A power supply unit with country adapters for EU, UK, US, and AUS
  • 3.5 mm cable  for TV headphone audio out
  • RCA audio adapter cable for analog TV analog audio out.
  • Digital optical cable for TV digital audio out.
  • Silicone ear pads (S/L), Memory foam ear pads, Open foam ear pads
  • Instruction manual
Price & Availability
The Sennheiser RS-5200 wireless TV headphones are currently available in the UK (£229.99 at Amazon.co.uk), Europe (€249.90 at Amazon.de),  and Australia ($430 AUD at Amazon.com.au). It will be available soon in the U.S. (pricing TBD).
For more information: sennheiser.com
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Shopping for wireless noise cancelling over-ear headphones or gaming headsets? Here are our picks for best you can buy on any budget.
At $249, the Amazon Fire TV Soundbar Plus features 3.1 channels, but is expandable to 5.1 with optional wireless subwoofer and speakers.
Daily Deals
Our favorite headphones on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $499, can the planar magnetic sound coming out of the Edifier STAX Spirit S5 wireless headphones make up for its hefty price tag?
