Headphones
Sennheiser RS 220 Wireless Headphones
Sennheiser announced the RS 220 audiophile-grade, digital wireless headphones offering uncompressed stereo sound with total freedom of movement. Dynamic transducers with powerful neodymium magnets ensure clear, lifelike audio reproduction with a frequency response of 19 to 21,000 Hz. The maximum sound pressure level of the open, circumaural headphones is 106 decibels. In the RS 220, the transmitter sends the audio signals to the headphones without compression via a stable 2.4 GHz connection using the so-called Direct Sequence Spread Spectrum (DSSS) technique.
“This is a frequency spreading process in which the output signal is spread to a width of 22 MHz by means of a specified bit sequence. If interference occurs at one point within this frequency range, the output signal experiences no interference as the data is transmitted with redundancy, in other words several times. As a result, only a minimal and inaudible part of the whole information is affected and the overall sound quality is not influenced,” explained Axel Grell, Senior Acoustical Engineer at Sennheiser. The headphones have a range of up to 100 meters without the need for the transmitter and receiver to be in the same room. A further advantage of the transmission process is the low latency and thus minimum delay of the audio signal.
As the data between the transmitter and receiver is transmitted wirelessly in the RS 220, the feeding of the data from the audio source to the transmitter is particularly important. For this reason, the headphone system has an analogue, a coaxial digital and an optical digital input. Discerning users can decide themselves on the type and quality of the audio signal being fed in. Sensor buttons on the transmitter or directly on the headphones enable users to switch back and forth between the sources.
Sennheiser RS 220 Wireless Headphones - Back
Conventional digital data transmission sometimes reduces dynamic range, as an optimum signal volume for the entire data package is often assigned to the information when the analogue signal is converted into a digital data package. To preserve the original dynamics of a piece of music, the RS 220 completely dispenses with the automatic level control function. The data of the digital sources is transmitted unchanged, and the user can manually adjust the reference volume for the analogue inputs. As a result, the system comes very close to the audiophile ideal: a lifelike sound experience.
Operating the RS 220 is extremely easy. An on/off switch, controls for selecting the audio source and tracks, as well as a volume control are directly integrated into the headphones. There is also a control to individually adjust the volume balance between right and left. Setting up the wireless headphones for the first time is equally easy. Simply connect the transmitter to the audio or video device using the chosen connector, put on the headphones and switch on. The headphones come with rechargeable batteries that guarantee up to eight hours of listening enjoyment and which can be conveniently recharged while still in the headphones. As an added feature, the transmitter can also be used to supply a second optional set of headphones — for shared listening pleasure.
Price and Availability
The Sennheiser RS 220 wireless headphones are now available for pre-order at $599.99.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
If you're looking for a better sounding alternative to Apple AirPods, these are the best true wireless earbuds of 2021 so far.
Daily Deals
Our favorite wireless noise cancelling earbuds on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and...
