Headphones
Sennheiser PXC 360 BT Headphones and MM 550 TRAVEL Headset
Sennheiser announced the PXC 360 BT headphones and the MM 550 TRAVEL headset which are both Bluetooth-enabled and equipped with NoiseGard-2.0 to shield against external noise. With Sennheiser's acoustics and SRS WOW HD SurroundSound technology you're guarantee a journey into a very special world of sound.
Sennheiser's active noise-cancelling system lets you simply 'switch off' annoying noise from aircraft engines and trains. At the push of a button, NoiseGard-2.0 technology minimises low-frequency background noise. The active noise-cancelling effect of the two travel headphones is supported by a high level of passive attenuation: the closed design, large circumaural ear cups and the use of noise-attenuating materials successfully keep out high-frequency noise. As a result the sound level is reduced by up to 23 dB. At the same time, the TalkThrough function allows you to conduct a conversation with your neighbour or the cabin crew whenever you like without removing the headphones.
PXC 360 BT Bluetooth Wireless Headphones
Sennheiser PXC 360 BT Bluetooth Headphones
Whether you are using a mobile phone, MP3 player, computer or PDA — the Bluetooth interface of the PXC 360 BT and the MM 550 can connect with a wide range of portable video and audio devices. Thanks to apt-X codec technology, Bluetooth A2DP connectivity enables wireless streaming of excellent-quality digital audio with minimal delay. Powerful Neodymium magnets and Sennheiser's Duofol diaphragms ensure detailed, lifelike sound reproduction in a frequency range of 15 to 22,000 Hertz. And the special SRS WOW HD feature immerses you in a fascinating world of sound: SurroundSound spatially expands the sound image to provide an intensive sound experience with powerful bass.
For those occasions when it is not possible to use Bluetooth on some airlines, the headphone set includes an audio cable and an adapter for use with in-flight entertainment systems — all you need for perfect relaxation above the clouds.
MM550 Adds Microphone Enabling Bluetooth Calling
Sennheiser MM 550 TRAVEL Bluetooth Headset
Travelling almost inevitably means making phone calls. The MM 550 TRAVEL not only enables you listen to music without being disturbed, it also lets you make phone calls no matter how much background noise there is. The NoiseGard function reduces the level of background noise during telephone calls, thus improving intelligibility.
A control unit integrated into the ear cup allows you to conveniently take incoming phone calls. A simple push of a button is enough to establish the connection. And the AVRCP Bluetooth protocol allows you not only to regulate the volume on the MM 550 and PXC 360 BT but also to select individual tracks. The Bluetooth, SurroundSound and NoiseGard functions can also be directly activated at the ear cups — taking you into a different world at the push of a button.
The PXC 360 BT and the MM 550 TRAVEL will be delivered to Sennheiser sales partners from July.
Technical data
Transducer principle: dynamic, closed
Ear coupling: circumaural
Bluetooth version: Bluetooth 2.1 + EDR / supported profiles: A2DP, AVRCP, for MM 550 also HSP and HFP
Range: ≤ 10 m
Frequency response (headphones): 15 – 22,000 Hz
Sound pressure level (SPL): 105 dB (1 kHz / 1 Rms)
Impedance: 590 Ω / 100 Ω (active / passive)
THD, total harmonic distortion: < 0.1% (1 kHz)
Noise reduction: 23 dB, NoiseGard 2.0
Frequency response (microphone): 100 – 10,000 Hz
Pick-up pattern (microphone): omnidirectional
Battery specification: 3.7 V / lithium-polymer
Weight: 179 g
Accessories: audio cable, in-flight adapter, 6.3-mm audio adapter, USB charging cable, plug-in mains unit with travel adapters, lithium-polymer accupack, carrying case
“The PXC 360 BT and the MM 550 TRAVEL are the perfect companions for frequent travelers. They not only effectively keep out most of the background noise, they also combine high-end sound quality with the convenience of wireless audio transmission.”
— Christian Ern, product manager at Sennheiser
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
From Meze's 99 Classics 2nd Gen and Sennheiser’s HDB 630 to Aavik's U 288 and Wharfedale's Super Denton, this round-up covers the standouts in...
Sennheiser HDB 630 delivers high-res 24-bit/96kHz wireless audio with aptX Adaptive, smart ANC, and the BTD 700 dongle for Android, iOS, and desktop.
Sennheiser's new flagship wireless noise cancelling headphones arrive Oct 21st for $499.
Can you build a killer desktop headphone rig for $500, $1000, or $2000? These DAC/amp combos prove you don’t need to go broke for...
Sennheiser HD 500 BAM adds a pro mic to 500 series headphones. No support for other brands, but max compatibility with PCs, consoles and...
