Sennheiser MOMENTUM Wireless Headphones (3rd gen, 2019)
Sennheiser just introduced third-generation MOMENTUM over-ear wireless headphone with active noise cancellation, Auto On/Off and Smart Pause.
Sennheiser MOMENTUM Wireless Headphones in Black worn on woman
Premium Noise Cancelling Over-ear Headphones
Sennheiser just introduced third-generation MOMENTUM over-ear wireless headphone with active noise cancellation for $399. Although they mostly look like the previous model, the 2019 MOMENTUM’s feature Auto On/Off and Smart Pause features, so they start up instantly when unfolded, and sense when put on or taken off to pause and resume playback. Designed to be supremely comfortable for all-day listening sessions, they feature genuine sheep leather and soft padding on the earpads and headband. Active Noise Cancellation and a Transparent Hearing function allow listeners to experience their audio on their terms, by either blocking out the world or staying aware of their environment. One-touch voice assistant access lets them stay connected on the move.
Updated technology
Sennheiser’s new MOMENTUM Wireless headphones are powered by 42mm transducers to reproduce the balanced depth and precision of a studio recording. This flawless audio performance is ensured by Bluetooth 5 compatibility and support for codecs including aptX, AAC, and SBC, as well as aptX Low Latency for perfectly synchronizing audio with onscreen visuals. Whether listeners are enjoying music, movies or podcasts or simply want to fine-tune the audio experience to their taste, it is possible to tailor the audio experience with the built-in equalizer via Sennheiser’s Smart Control app.
Sennheiser MOMENTUM Wireless Headphones front view in Black
Intuitive
With the new generation of MOMENTUM Wireless, interaction is supremely intuitive thanks to a unique combination of features that offer fast access to one’s music. Auto On/Off instantly turns on or off playback as the earcups are folded open or closed, while Smart Pause uses proximity sensors to pause audio when the headphones are removed and to resume playback when they are slipped back on. Just as effortless is a three-button interface that gives control of audio or calls – all without the need to consult a manual. Via a dedicated button, the MOMENTUM headphones feature one-touch access to voice assistants such as Siri and Google Assistant, while Amazon Alexa integration will be available soon with a firmware update via the Sennheiser Smart Control app. Pairing is effortless as well, thanks to NFC and an automatic pairing mode that makes setting up on initial activation a breeze.
Sennheiser MOMENTUM Wireless Headphones side view in Sandy White
ANC Adaptability
No matter where the MOMENTUM Wireless headphones are being enjoyed, they are able to adapt to every environment. When on the go, Active Noise Cancellation with three different modes blocks out the outside world. Alternatively, the Transparent Hearing function lets listeners enjoy their music and still be aware of ambient sounds in their surroundings – perfect for environments that require greater situational awareness.
Comfort & Usability
Like all MOMENTUM headphones, the new generation model maintains the signature look with genuine sheepskin leather earpads and pearl-blasted stainless steel sliders. The leather on the padded ear pads and headband is ultra soft for improved wearing comfort, even for longer listening sessions made possible by the 17-hour battery life. Meanwhile, the strong yet lightweight stainless steel sliders and hinges maintain a purity of design while also ensuring the headphones remain robust enough for a lifetime of listening on the move. The folding headband design allows the headphones to fold away in their fashionable fabric carry case.
Hard to Lose
With the new MOMENTUM Wireless, it is easy to lose oneself in the music, but thanks to smart Tile technology, the headphones are almost impossible to misplace. The integrated Bluetooth tracker ensures users can find their headphones via the Tile app.
Sennheiser MOMENTUM Wireless Headphones front view in Sandy White
Price & Availability
The new Sennheiser MOMENTUM Wireless is available in black as of now for $399.95 (MSRP). A sandy white color variant will be available from November 2019.
In the box
  • Audio 3.5 mm
  • USB-C to USB-A Adapter
  • USB-C Cable
  • Case
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
If you're looking for a better sounding alternative to Apple AirPods, these are the best true wireless earbuds of 2021 so far.
Daily Deals
Our favorite wireless noise cancelling earbuds on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and...
