Sennheiser MOMENTUM True Wireless 5 Earbuds Add Dolby Atmos, Bluetooth 6.0 and Replaceable Batteries
At $299, Sennheiser’s flagship wireless earbuds for 2026 aim to improve comfort, ANC, and call quality while introducing a refined design and new color options.
2026 Sennheiser Momentum True Wireless 5 Earbuds Colors
Sennheiser has expanded its MOMENTUM lineup with the MOMENTUM True Wireless 5, its new flagship true wireless earbuds and the successor to the MOMENTUM True Wireless 4.
Inspired in part by the full-size MOMENTUM 5 Wireless Headphones, the MOMENTUM True Wireless 5 introduce several major upgrades to Sennheiser’s premium earbud platform, including Dolby Atmos support, Bluetooth 6.0, aptX Lossless, and replaceable batteries in both the earbuds and charging case.
2026 Sennheiser MOMENTUM True Wireless 5 Lavender inside charging case
The MOMENTUM True Wireless 5 build on the same sound-first philosophy behind Sennheiser’s full-size MOMENTUM 5 Wireless headphones, while adapting that approach for a much smaller true wireless design.
7mm TrueResponse Dynamic Drivers
The MOMENTUM True Wireless 5 use Sennheiser’s 7mm TrueResponse dynamic transducers, which are designed to deliver detailed reproduction while retaining the fuller, bass-driven presentation associated with the MOMENTUM lineup. Each transducer is manufactured at Sennheiser’s facility in Tullamore, Ireland.
Listeners can further customize the sound through the Sennheiser Smart Control Plus App, which includes an 8-band equalizer for more precise tonal adjustment.
Bluetooth 6.0, aptX Adaptive and Lossless Audio
The MOMENTUM True Wireless 5 support Bluetooth 6.0 along with aptX Adaptive, providing a high-resolution wireless audio pathway up to 24-bit/96kHz with compatible source devices. The earbuds also support aptX Lossless, enabling bit-perfect CD-quality wireless transmission when paired with a compatible source and under appropriate connection conditions.
sennheiser-momentum-true-wireless-5-earbuds-cream
MOMENTUM True Wireless 5 (cream)
Revised Adaptive ANC and Smarter Voice Isolation
The MOMENTUM True Wireless 5 feature a revised adaptive hybrid active noise cancellation (ANC) system along with an automatic anti-wind mode designed to reduce unwanted noise in changing environments.
A redesigned ear tip works with a four-microphone array to improve isolation and maximize ANC effectiveness, while Sennheiser also claims its most natural-sounding real-time transparency mode yet for the MOMENTUM True Wireless series.
For calls and voice capture, the earbuds use eight system sensors, including six microphones and two bone-conduction voice accelerometers. An AI-based speech-extraction algorithm analyzes those inputs to isolate the wearer’s voice more effectively, particularly in noisy surroundings.
Dolby Atmos Spatial Audio With Head Tracking
Borrowing from the spatial audio capabilities of the full-size MOMENTUM 5 Wireless headphones, the MOMENTUM True Wireless 5 are optimized for Dolby Atmos and support interactive head tracking. The technology is designed to create a more immersive spatial presentation by keeping sounds anchored within the virtual sound field as the listener moves their head.
User-Replaceable Batteries Extend Product Life
The MOMENTUM True Wireless 5 feature user-replaceable batteries in both the earbuds and wireless charging case, allowing owners to replace aging power cells rather than retire the entire product when battery performance eventually declines. It is an unusually practical approach for premium true wireless earbuds and could significantly extend their usable lifespan while reducing electronic waste.
Up to 40 Hours of Battery Life
The MOMENTUM True Wireless 5 improve battery life over the previous-generation MOMENTUM True Wireless 4, providing up to 12 hours of continuous playback on a single charge. The Qi-compatible wireless charging case provides additional recharges for up to 40 hours of total listening time.
For users caught with a nearly depleted battery, the quick-charge function provides up to one hour of playback from an eight-minute charge.
The MOMENTUM True Wireless 5  supports improved playback time over the previous Momentum 4 with 12 hours of continuous playback per charge. With two additional replenishments stored in the Qi-enabled wireless charging case, up to 40 total hours of run time is supported. Quick charge capability extends listening up to 1 hour from just an 8-minute charge.
Sennheiser on Replaceable Batteries
“Balancing compact size, our signature high-fidelity acoustics, and a replaceable battery is a major breakthrough,” said Lilika Beck, President of Sennheiser Consumer Hearing. “With MOMENTUM True Wireless 5, we are proving that cutting-edge performance does not have to sacrifice longevity.”
“We set out to bring the larger-than-life sound and connected technology of the MOMENTUM series into a remarkably compact format,” said Frank Foppe, Product Manager. “From its exquisite audio reproduction to the advanced hardware powering it all, MOMENTUM True Wireless 5 represents our most advanced integration of audio technology in an earbud.”
sennheiser-momentum-true-wireless-5-earbuds-blue-case
Redesigned Fit, IP54 Protection and a Slimmer Charging Case
For a more unobtrusive fit, the MOMENTUM True Wireless 5 feature a newly sculpted, aerodynamic housing developed using data gathered from thousands of individual ear models.
The earbuds also adopt a fin-less design that Sennheiser says was rated more comfortable than the previous generation by 73% of testers. An IP54 rating provides protection against dust, sweat, and splashes, while a micro-perforated acoustic microphone plate is designed to reduce wind turbulence that can interfere with voice pickup and ANC performance.
Sennheiser has also redesigned the charging case with a narrower, more pocket-friendly shape and a low-friction finish intended to make it easier to slide in and out of pockets.
Comparison
sennheiser-momentum-true-wireless-5-vs-4-earbuds
5th generation vs 4th generation
Sennheiser Model Momentum True Wireless 5 (MTW5)Momentum True Wireless 4 (MTW4)
Release DateSeptember 3, 2026February 29, 2024
Product Type TWS EarbudsTWS Earbuds
Price $299.95$299.95
Ear coupling Ear canal Ear canal
Connectivity Bluetooth 6.0 Bluetooth 5.4
Supported profiles A2DP, AVRCP, HFP A2DP, AVRCP, HFP, TMAP, PBP
Supported codecs SBC, AAC, aptX, aptX Adaptive/Lossless, LE Audio and Auracast (firmware update required) SBC, AAC, aptX, aptX Adaptive/Lossless, LC3 – LE Audio and Auracast
Dolby Atmos Yes – with head trackingNo
Speaker Principle Dynamic Dynamic
Speaker Type/size 7mm dynamic TrueResponse transducer7mm dynamic TrueResponse transducer
Speaker frequency range 5 Hz to 21 kHz 5 Hz to 21 kHz
Speaker sensitivity 107 dB SPL (1 kHz / 1 mW) 107 dB SPL (1 kHz / 1 mW)
Speaker THD <0,08% (1 kHz / 94 dB) <0,08% (1 kHz / 94 dB)
Active Noise Cancellation Hybrid Adaptive ANC Hybrid Adaptive ANC
Mic principle MEMS MEMS
Mic frequency range Up to 16 kHz (super wideband telephony mode) 100 Hz to 10 kHz
Mic pick-up type 4 mics per earbud incl. bone-conducted mic; AI and beamforming for de-noising 3 mics per earbud, beamforming for noise reduction
Battery lifespan Up to 12 hrs music playtime with earbuds (ANC off)
Up to 6 hrs music playtime with earbuds (ANC on)
Up to 40 hrs overall music playtime with charging case (test condition: iPhone, mid volume level)
Up to 7.5 hrs music playtime with earbuds (ANC off)
Up to 7.0 hrs music playtime with earbuds (ANC on)
Up to 30 hrs overall music playtime with charging case (test condition: iPhone, mid-volume level 85 dB)
Charging time Approx. 1.5 hrs for a full charge.
After 8 min of charging, 1 hr of music playtime.
Note: Ambient temperatures <15°C or >30°C and Qi wireless charging lead to extended charging times
Battery type Lithium-Ion rechargeable batteries, User replaceable with standard tools, Left/right earbud: 72 mAh, Charging case: 760 mAh Built-in (not replaceable) Lithium-Ion rechargeable batteries; Left/right earbud: 75 mAh, charging case: 820 mAh
Power supply 5 V⎓, 1000 mA max., charging power up to 5 W, USB-C charging socket, no Power Delivery (PD), Qi Wireless Charging (Version 2.1) 5 V⎓, 1000 mA max; USB charging via USB-C socket at charging case; Qi Wireless charging
Weather resistance IP54, dust and splash resistant (earbuds only) IP54, dust and splash resistant (earbuds only)
Product dimension 67.2 x 48.4 x 25.0 mm (case with earbuds) 70.1 x 44.6 x 34.8 mm (case with earbuds)
Product weight 7 g (single earbud)
69 g (both earbuds and charging case)
6.2 g (single earbud)
72.4 g (both earbuds and charging case)
App support Sennheiser Smart Control Plus app for iOS and AndroidSennheiser Smart Control Plus app for iOS and Android
sennheiser-mtw5-vs-mtw4-case-copper
Charging Cases Compared: MTW5 (left) vs. MTW4 (right) in copper
The Bottom Line
The Sennheiser MOMENTUM True Wireless 5 enter a very crowded premium wireless earbud market at $299.95, but this is more than a cosmetic refresh of the MOMENTUM True Wireless 4. The 7mm TrueResponse driver remains central to the design, while Sennheiser has added Dolby Atmos with head tracking, Bluetooth 6.0, improved adaptive ANC, a more sophisticated microphone and voice-isolation system, longer battery life, and the expanded 8-band EQ available through the Smart Control Plus app.
The most unusual upgrade, however, may be the user-replaceable batteries in both the earbuds and charging case. Battery degradation remains one of the biggest limitations of true wireless earbuds, and allowing owners to replace the cells rather than discard an otherwise functional $300 product gives the MOMENTUM True Wireless 5 a meaningful longevity advantage over most competitors.
Sennheiser has also held the line on price. The $299.95 MSRP is the same price at which the MOMENTUM True Wireless 4 originally launched, although the outgoing model is now heavily discounted as it makes way for its successor. That puts the MTW5 above Apple’s $249 AirPods Pro 3, level with the Bose QuietComfort Ultra (2nd gen) and Technics EAH-AZ100, but below luxury models such as the Bowers & Wilkins Pi8.
There is also an important connectivity feature worth clarifying: Bluetooth LE Audio and Auracast are supported. Sennheiser says the functionality will be enabled through a future firmware update rather than being available at launch. That means buyers will not need new hardware to take advantage of Auracast once the update arrives, and existing owners will receive the feature through the same firmware path.
Ultimately, Sennheiser has given buyers more than just another annual collection of software tweaks. Dolby Atmos, aptX Lossless, improved ANC and call performance are all welcome, but the replaceable battery system is the feature that could make these earbuds considerably more appealing to listeners who would prefer their expensive wireless headphones to last longer than the batteries sealed inside them.
sennheiser-mtw5-colors
Price & Availability
The Sennheiser MOMENTUM True Wireless 5 will be available in five metallic colors: Graphite, Cream, Copper, Denim, and Lavender, and will begin shipping on September 3, 2026 from sennheiser-hearing.com and select retailers at an MSRP of $299.95 USD.
Where to buy: $299.95 at Amazon
3 Comments
3 Comments
  1. Silent
    August 20, 2026 at 12:40 pm
    I’m confused with one thing: there is no TMAP profile (which is present in Momentum 4 TWS, but at the same time:
    Mic frequency range Up to 16 kHz (super wideband telephony mode).
    Isn’t SWB telephony mode is LC3 based TMAP part? I’m really interested if Sennheiser have newer chipset with BT6.0 but firmware not support LE Audio profiles which was there on older model, or it’s just incomplete specifications?
    Replaceable battery is great appeal for quality buds with not so low price – buying good product once and change battery is a way to expect at least 5 years in use. Without this repairability I always consider below $150 products to treat them as disposable with 2-3years of service expected (which is definitely sacrifice sound in comparison with Sennheiser).
    • Ian White
      August 20, 2026 at 2:12 pm
      Silent,
      There were a few specs missing from the material they provided but I think some of the other features were not included at launch. Might be a firmware update in a few months. No Auracast at launch even though it was supported by the Momentum 4.
      IW
  2. ORT
    August 20, 2026 at 3:36 pm
    As regards improvements to anything audio: Can you actually, via double blind testing, hear an “improvement”. BT6 is said to objectively provide “precise distance measurement, scanning efficiency and data handling architecture”.
    The first part of that explanation means that devices can now know precisely how far apart they are, supposedly within a couple of inches. Kinda sorta like GPS have gotten far more accurate over the years. Yup. Really. That’s it.
    The second part, scanning efficiency means your Bluetooth devices spend less time and power sorting through surround electronic devices. In English they won’t spend power/time looking at devices they aren’t connected to to see if it should be connected to them. Better use of battery power by not wasting battery power? Yup!
    The third and final part is data is more efficiently organized within the Bluetooth data stream. In the case of music, it repackages the stream mo’ better to prevent for example, music stuttering.
    I hope this in a nutshell (I am a nutcase!) = helps.
    ORTacles of Thebes
2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
2026 Triangle Borea BR05 Stand-mount Loudspeakers 2026 Triangle Borea BR05 Stand-mount Loudspeakers
Triangle’s Borea BR05 combines retro styling, an 8-inch woofer, and serious cabinet engineering. Who decided bookshelf speakers had to be so small?
Moon 341 Integrated Amplifier Black Angle Moon 341 Integrated Amplifier Black Angle
2026 Audiolab PPA7 Phono Preamp Black LIfestyle 2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
EarFun's flagship wireless noise cancelling headphones for 2026 offer adaptive ANC, Auracast, aptX Lossless, 90-hour battery life and custom EQ.
iFi’s $699 iDSD GR 2 MT adds Steve Levine tuned PCM and DSD filters, a ceramic PCB, upgraded I/V stage and Audio Note Kaisei...
The $599 iFi GO pod Max adds aptX Lossless, powerful amplification and interchangeable connectors to turn high end wired IEMs into wireless earphones.
Dongle DACs
Bluetooth may no longer have to do everything. Qualcomm’s new audio platform adds Wi-Fi 6E, XPAN lossless streaming and smarter ANC.
TRIBIT's $39.99 wireless earbuds come feature packed with noise cancellation, Bluetooth 6.0, multipoint and up to 8 hours of battery life per charge.
