Sennheiser HD 800 Audiophile Headphones
Sennheiser HD 800 Over-ear Open-back Headphones
Sennheiser’s Top-of-the-range Headphones
Sound that is as natural as possible and true in every detail: that has always been the vision of all audio developers. With its new HD 800, Sennheiser has now come closer to this target than any other headphones manufacturer has ever done. The new top-of-the-range model from the audio specialist features a completely novel type of transducer and an innovative ear cup design. The key component of the stereo headphones is a 56 mm sound transducer — currently the largest that can be found in dynamic headphones. With the new headphones, Sennheiser is following the tradition set by the legendary Orpheus and has developed a set of high-end headphones that offers the ultimate in reproduction precision and unique spatiality.
Sennheiser HD 800 Over-ear Headphones
Sennheiser is presenting its new top-of-the-range HD 800 headphones aimed at highly discerning audiophiles who are looking for the ultimate in sound reproduction. With their completely open design, the dynamic stereo headphones combine innovative technology with carefully selected materials and the highest quality workmanship. The result is a level of performance, quality and attention to detail that is clearly audible. The headphones offer an outstanding frequency response of 6 to 51,000 Hz, a brilliant sound image and impressive spatiality. The appearance of the HD 800 is also in keeping with its exceptional sound performance: a puristic design language and a black/silver finish give the headphones a look of exclusive elegance. “We allowed ourselves a lot of time to perfect the HD 800,” explained Maurice Quarre, Product Manager Home Audio at Sennheiser. “Not only to develop the technical intricacies but also to select the finest materials — in other words, we took the time that was necessary to make it perfect in every detail. After all, the sound properties of headphones ultimately depend on the interaction between all the individual components.”
Sound reproduction that is true in every detail: the patented transducer principle
Measuring 56 mm, the transducer in the HD 800 is the largest that can currently be found in dynamic headphones. A completely new design principle allows the purest possible sound reproduction in exceptional detail. The vibrating part of the diaphragm is not a circular surface area but a ring. This ring is able to set the entire air volume over the transducer into motion, generating the full-bodied sound of the HD 800.
The annular design patented by Sennheiser solves the problems relating to the dynamic transducer principle for the first time: “The more transducer surface area is caused to vibrate, the purer the headphone sound becomes at low frequencies. However, transducers with a large surface area have the disadvantage that, at high frequencies, undesired resonances known as eigenforms occur at the diaphragm. This results in distortions in sound reproduction that even high-quality Duofol laminations are not able to completely eliminate,” explained Axel Grell, acoustics developer at Sennheiser. “This is precisely the dilemma that we have resolved in the HD 800. The ring design minimises the distortion of the sound image, even with a transducer as large as 56 mm.” The result is impressive: with total harmonic distortion of less than 0.02 percent (at 1 kHz and 100 dB sound pressure level), the HD 800 has brilliant trebles, precise bass reproduction and a much clearer sound image.
Natural listening experience: the new ear cup design
In the development of the HD 800, special attention was also paid to the design of the ear cups. These are designed in such a way that the sound waves are directed to the ear at a slight angle. This produces an impressively natural listening experience. “We perceive acoustic signals to be natural when we experience them with a spatial extension,” is how Axel Grell describes the basic idea. “Today, most music is made to be reproduced by two loudspeakers, which form an equal-sided triangle together with the listener. This results in a sound field close to the ears that is at a slight angle to the head. When the sound field reaches the ears, the sound is reflected into the ear canal and to the ear drum by the structures of the external ear with slight time differences. It is precisely these differences that are a key factor in spatial hearing and in the localisation of the sound event outside the head. With its large, inclined transducers, the HD 800 generates a sound field that corresponds to the listening experience with loudspeakers, but far exceeds loudspeakers in the purity of the sound reproduction.”
The ultimate in sound reproduction and wearing comfort: top-quality materials and finish
The exceptional sound properties of the HD 800 are supported by selected materials and a top-quality finish. To ensure that the acoustic properties of the headphones are not impaired by any partial vibrations, the transducer is mounted in a specially produced high-precision gauze made of stainless steel. The ear cups are made of high-quality plastic with particularly good attenuation characteristics. What is more, there is no covering at all for the ear cups, as less material means that there is less opportunity for partial vibrations to occur. For the same reason, a special headband was developed for the HD 800. A patented multi-layer design consisting of metal and high-quality plastic attenuates all of the vibrations of the headband, thus effectively eliminating any dips in sound pressure level at low frequencies.
The cables have also been developed especially for these headphones. The four-strand high-performance wires made of silver-plated, low-oxygen copper are specially shielded against electromagnetic disturbance. The two high-precision plugs and the 1/4″ (6.3 mm) jack plug are gold plated for optimum contact.
The outstanding sound quality is accompanied by excellent wearing comfort. To guarantee optimum fit on the head, the ear cups are suspended on one side only. High-quality plastic material developed for the aviation and aerospace industries ensure maximum stability. With their circumaural design, the ear cups fit precisely round the ears without pressure and are still comfortable to wear even after hours of music enjoyment.
The HD 800 was developed and designed at Sennheiser’s corporate headquarters in Wedemark, Germany. And the new headphones will be produced there too — with the usual meticulous attention to detail. MSRP: $1,399.
EISA Award Winner
The Sennheiser HD 800 premium headphones have just won the coveted EISA Award presented by the European Imaging and Sound Association. In the category ‘European Audio Awards,’ the HD 800 impressed the international jury with its innovative transducer principle.
The EISA jury, which is made up of representatives from 50 European special interest magazines, justified its verdict: “Here is a new top-of-the-range model from one of the world’s most renowned headphone manufacturers. The challenge was to create a large diaphragm, essential for powerful bass reproduction, while avoiding unwanted resonances which result in distortion. The solution? Instead of the usual circular shape, the diaphragm is designed as a ring, which provides a large surface area, yet minimizes distortion. The sound is just true to the original, at every frequency from the lowest bass to the highest treble.” The coveted EISA Awards are presented every year for products from the fields of photography, video, audio & home theatre, in-car electronics and mobile devices.
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
From Meze's 99 Classics 2nd Gen and Sennheiser’s HDB 630 to Aavik's U 288 and Wharfedale's Super Denton, this round-up covers the standouts in...
Sennheiser HDB 630 delivers high-res 24-bit/96kHz wireless audio with aptX Adaptive, smart ANC, and the BTD 700 dongle for Android, iOS, and desktop.
Sennheiser's new flagship wireless noise cancelling headphones arrive Oct 21st for $499.
Can you build a killer desktop headphone rig for $500, $1000, or $2000? These DAC/amp combos prove you don’t need to go broke for...
Sennheiser HD 500 BAM adds a pro mic to 500 series headphones. No support for other brands, but max compatibility with PCs, consoles and...
