Sennheiser’s HD660S2 Headphones Offer a New Twist on a Classic
The Sennheiser HD660S2 are a substantial refresh of one of their best-selling headphones and we have a review sample incoming.
Sennheiser HD6600S2 Headphones Lifestyle
Sennheiser has been engineering high-end headphones for almost 75 years and whilst there has been a lot of recent changes, the German manufacturer is still considered to be one of the leading brands in the category.
There was some concern when Sonovo took over the consumer products division that the focus on audiophile products might become less important to the company with its relatively small market and high R&D costs — but so far Sonovo appears to have decided to refresh the audiophile categories with new IEMs, wireless headphones, and the brand new Sennheiser HD660S2 that were just introduced earlier this week.
This is a big deal because the HD660S was already a really good headphone with a significant following.
I have lost track of the number of times I’ve recommended the HD650 and HD660S over the years as they sit right in the sweet spot for price/performance and it’s hard to get something better without spending a lot more.
This new model follows in the footsteps of its predecessors having been designed in Germany and it will be assembled in Ireland on the same production equipment used for the HD650 and HD660S.
Externally, the changes are minor with the HD660S2 retaining the same basic frame and color-ways as its predecessor with brass badging distinguishing it from the earlier versions.
The cups are the same external dimension (although dramatically redesigned internally) and use the same connectors as other HD6x0 models; which means that all of the third party pads, cables, and accessories will work with the new HD660S2.
That’s good news for those who have invested in XLR cables or other high-cost accessories.
The other good news is the HD660S2 ships with both a 6.35mm and a 4.4mm balanced cable so purchasers may not need aftermarket options.
The Skinny
“Our new Sennheiser HD 660S2 offers listeners what they requested most from the headphones’ predecessor,” says Jermo Koehnke, Sennheiser Audiophile Product Manager. “With precision and power like no other and new sensitivity across all frequencies, listeners will hear details they’ve never heard before, especially at the lower end of the spectrum.”
The Depth and Drama Audiophiles Crave
Improving on a beloved classic while retaining its best traits was a challenging task, starting with the lowest end of the frequency plot. The HD 660S2’s warm bass characteristics pair perfectly with its silky-smooth treble performance and trademark vocal presence, allowing the timbre and uniqueness of any instrument part to stand out.
Across the entire frequency spectrum, the HD 660S2 delivers a refined listening experience thanks to improved transducer airflow and a refined voice coil. From thunderous timpani crescendos to pulsating EDM rises, even the most discerning audiophiles will notice the depth and nuance of low-frequency passages, adding dramatic flair to any type of music.
Ultimately, listeners are treated to deeper, clearer bass without sacrificing the expansive detail the series is known for. By reducing the voice coil’s weight, impulse response improves, bringing hyper-realistic textures to the forefront of any performance reproduction.
The overall experience is smoother and warmer than the original HD 660S, thanks to ​ that reduces the distances between select peaks and troughs. The overall impedance matches that of the HD 600 and HD 650, at an audiophile-friendly 300 ohms, for punchy dynamics and impressively low distortion.
Sennheiser HD6600S2 Headphone Parts Exploded
Fit
Designed in Germany and manufactured at Sennheiser’s state-of-the-art Ireland production facility, the HD 660S2 continues the series’ emphasis on quality, functional design using materials that contribute to the hi-fi experience.
Plush earpads and cushy headband padding place the revised 300-ohm transducers at the optimal distance from the ear resulting in a spacious soundstage with an abundance of detail — even for extended musical exploration. The transducer surround drops the resonant frequency from 110 Hz (original HD 660S) down to 70 Hz for hefty kick drums that move with ease. Even the outer mesh grilles are crafted to manage airflow at the ideal impedance for exquisite open-back listening sessions.
Sennheiser HD6600S2 Headphones Angle
Versatile enough to connect to vintage classics and modern solutions alike, the HD 660S2 ships with two 1.8 meter (5.8 ft) user-detachable cables that terminate to 6.3 mm (1/4-inch) single-ended stereo and 4.4 mm balanced stereo jack plugs, respectively.
A 6.3 mm to 3.5 mm (1/8-inch) adapter is also included, for use with popular hi-fi gear from DAC-amps, DAPs, and dedicated amplifiers such as the Sennheiser HDV 820. Distinguishing bronze accents complement the elegant jet-black finish, all of which is protected by a storage pouch.
We have our request in now for a review pair and will be sure to post and in-depth review as quickly as we can get a pair in hand.
Pricing & Availability
The Sennheiser HD 660S2 are available now for $599.95 at Amazon and Crutchfield.
5 Comments
5 Comments
  1. bob dog
    February 9, 2023 at 6:13 pm
    $600? Pass. Hard pass.
    • Ocean
      February 11, 2023 at 1:13 pm
      I waited a long time for the HD 600 to mature. It has finally arrived as the HD 660S2. I’ll wait a little longer hoping for Sennheiser to run a special at Canjam 2023 NYC or something? For at $600 the competition is fierce!
      • Ian White
        February 11, 2023 at 5:50 pm
        Ocean,
        I think the price is actually quite reasonable. Especially compared to the Meze 109 Pro and entry-level planar models from Audeze.
        Best,
        Ian White
        • Elysian
          February 15, 2023 at 3:26 pm
          Seriously, there are so many better alternatives like Hifiman Edition xs Focal Elex at this price point. $600 with a tuning that is warmer than it’s predecessor, which already sounded too dark with not enough pinna gain? Hard pass. Stop chilling things.
          • Ian White
            February 15, 2023 at 4:03 pm
            Elysian,
            I own 5 pairs of HiFiMAN headphones so I’m not the one you need to convince. Until I try these at CanJam NYC in 10 days, I can’t say if they are good/bad.
            A part of me wonders if they were tuned to match the overwhelming number of Dongle DACs that are on the analytical side. We shall see.
            Best,
            Ian White
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
Gaming is driving the headphone market and Sennheiser's new HD 550 might be a fantastic option below $300 for audiophiles and gamers.
Over-Ear Headphones
HiFiMAN Arya Unveiled open-back headphones feature exposed planar magnetic drivers and an all-new sound. Find out how it compares to the prior Organic and...
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
