Sennheiser’s HD 490 PRO Reference Studio Headphones Are Only $400: NAMM 2024
Sennheiser’s new HD 490 Pro and HD 490 Pro Plus Studio Headphones made their debut at NAMM 2024 and are super impressive for $400. Review forthcoming.
Sennheiser HD 490 PRO Plus Studio Headphones
NAMM 2024 is ongoing this weekend and we decided to spend some with a number of brands that offer both pro audio and consumer A/V models in the headphone and loudspeaker categories.
There has been some convergence of late across both segments and that’s a good thing for audiophiles. Brands like Theory Audio/Pro Audio Design and Sennheiser are evidence that you can offer consumers more robust build quality, superior sound quality, and greater value for your money if you know that you are doing.
Sennheiser today launched its brand-new open-back HD 490 PRO reference studio headphones, purpose-built for producing, mixing and mastering. The circumaural, dynamic headphones feature highly precise sound reproduction and a very wide and realistic sound stage.
This superior accuracy and range give producers, mixing and mastering engineers, as well as musicians, the transparency they need for critical mixing decisions and for confidently resolving any panning placement issues.
The Sennheiser HD 490 PRO and HD 490 PRO Plus (includes additional accessories) will be available from the end of January.
Sennheiser HD 490 PRO Plus includes a case, additional 3 m headphone cable and an extra fabric headband pad. The headphone itself is the same.
“If you compare today’s music productions with that of ten, 20 years ago, you will notice how the massively increased computing power and complex parameter automation have changed the way in which music is made,” shares Jimmy Landry, Category Market Manager for MI at Sennheiser. “In every genre, engineers and music creators are continuously pushing boundaries, creating extremely complex mixes that can be prone to so-called ‘audio blind spots’. Mixes can be crowded and muddy, with too many instruments sitting at the same position and their frequencies competing. For the engineer or musician, it becomes difficult to hear each individual instrument or voice distinctly. This goes to show the importance of a good pair of studio headphones.”
Full-Range Accuracy
To tackle this complexity, the Sennheiser engineers have given the HD 490 PRO an extremely wide, dimensional sound stage for precisely localising the components of a mix. Ultralight voice coils ensure a fast and authentic sound reproduction.
The frequency response is uncoloured and honest across the entire audio spectrum, with the low end being full, accurate, and clearly defined thanks to a special low-frequency cylinder.
The open-mesh ear cup covers reveal Sennheiser’s Open-frame Architecture, which minimises resonances and distortion. For an optimal listening experience, the transducers sit at a slight angle, thereby emulating a typical monitor loudspeaker set-up.
“All these features combine to enable music professionals to identify and resolve any panning placement issues and troublesome low-end frequencies – ensuring clear mixes and superbly refined masters,” explains Gunnar Dirks, Sennheiser Product Manager. “The HD 490 PRO studio headphones put you in full control of every detail.”
Sennheiser HD 490 PRO Studio Headphones
Lightweight and Very Comfortable
Their lightweight, ergonomic design eliminates any pressure points, as the headband does not press on the sensitive parts of the head. Also, the circumaural ear pads feature a Sennheiser-patented soft comfort zone for the temples of glasses while maintaining good sealing.
A patent has also been applied for regarding the special axes geometry of the HD 490 PRO. This design makes sure that the headphones optimally adapt to the head when they are put on, and maintain an equal contact pressure no matter what the shape of the user’s head.
“When you’re creating music, the last thing you want is to be focusing on the fit of your headphones. The HD 490 PRO let you feel the music and forget about the headphones,” says Landry.
Sennheiser HD 490 Pro Earpads
Producing Earpads are darker, Mixing Earpads are lighter.
The Ear Pads Make a Huge Difference
Sennheiser are offering the HD 490 PRO with two sets of ear pads and we made a point of trying both; the change in tonal balance was not even remotely subtle and we wonder how many consumers outside of the Head-Fi space are aware of the differences.
The producing ear pads (velour) of the HD 490 PRO have a slightly warmer response to create perspective and help users make a holistic judgement of the sound. The mixing ear pads (fabric), on the other hand, allow for a very flat, neutral sound that helps dive into detail when a sound reference is needed in finishing off a mix. Both ear pads are washable – a solution that is both hygienic and sustainable.
Sennheiser HD 490 Pro Frequency Graphs with Different Earpads
“The development of the HD 490 PRO was preceded by the biggest professional headphone survey we ever did, where users voted neutral and flat reference audio as the most important feature,” explains Dirks. “However, when we took a look at market figures, we discovered that a slightly warmer sound was preferred over a 100% neutral response. Therefore, we decided to give our customers two headphones in one – by providing two different sets of ear pads that were carefully designed to shape the sound differently.”
Accessories and Flexibility
The meticulous design of this top-of-the-range studio model does not stop with the accessories. For example, the headphone cable can be plugged into the right or left ear piece of the HD 490 PRO to cater to different studio set-ups and preferences.
A patented cable coil structure ensures that the headphone cable does not transmit any noise when it hits the desk or rubs against the clothing.
The left/right designation is clearly visible on the inside dust covers of the transducers, while for the visually impaired, the headband fork carries braille information.
Each HD 490 PRO is delivered complete with two different sets of ear pads (mixing and producing) plus a 1.8 m headphone cable and a dearVR MIX-SE licence. It retails at EUR 399 (MSRP) or USD 399 (MAP).
The HD 490 PRO Plus, priced at EUR 479 (MSRP) or USD 479 (MAP), additionally includes a 3 m cable, a transport case, and an extra fabric headband pad in addition to the standard velour headband.
All Plus extras are also available as individual accessories.
A balanced headphone cable (EUR 39 MSRP, USD 39 MAP) is available as an optional accessory.
Specifications
  • Acoustic principle: open
  • ​Ear coupling: circumaural
  • ​Transducer principle: dynamic
  • ​Transducer diameter: 38 mm
  • ​Frequency response: 5 – 36,000 Hz, 100 Hz (-10 dB)
  • ​Sensitivity: 105 dB SPL (1 kHz/1 Vrms); 96 dB SPL (1 kHz/1 mW)
  • ​Max. sound pressure level: 128 dB SPL (1 kHz, 5% THD)
  • ​THD: <0.2% (1 kHz, 100 dB SPL)
  • ​Impedance: 130 ohms (1 kHz)
  • ​Power rating: 300 mW (100 h, noise IEC 60268)
  • ​Temperature range: operation: 0° C to +50° C; storage: -25° C to +70° C
  • ​Relative humidity: operation: 10 – 80% (non-condensing); storage: 10 to 90%
  • ​Weight (w/o cable): 260 g
Where to buy: $399 or $479 at Amazon
For more information: sennheiser.com
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
If you're looking for a better sounding alternative to Apple AirPods, these are the best true wireless earbuds of 2021 so far.
Daily Deals
Our favorite wireless noise cancelling earbuds on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and...
