Dongle DACs
Sennheiser BTD 700: aptX Adaptive, Auracast, and No More Bluetooth Bottlenecks
Sennheiser BTD 700 Bluetooth dongle boosts wireless audio with aptX Lossless, low latency, and Auracast—plug & play high-def sound for any device.
Sennheiser BTD-700 with Momentum4 Headphones
Sennheiser’s BTD 700 arrives as a sleek, no-nonsense Bluetooth dongle designed to fix a problem everyone with wireless headphones already knows: your device’s built-in Bluetooth is usually garbage. At just 2.2 grams and 24mm long, it’s smaller than most flash drives but packs serious firepower—aptX codecs, Auracast, and low-latency gaming modes all wrapped in one plug-and-play USB-C package.
Throw in the USB-A adapter, and suddenly your aging laptop or desktop isn’t holding back your headphones anymore. It’s the sort of elegant, minimalist fix Deiter Rams might reluctantly approve—because sometimes good design means fixing the basics first.
High-Def Bluetooth That Doesn’t Make Your Ears Cry
The Sennheiser BTD 700 isn’t here to kiss your Bluetooth woes goodbye—it’s here to stomp on them with aptX Lossless and aptX Adaptive codecs, delivering wireless audio up to a lush 24-bit/96 kHz. That means your earbuds, headphones, or speakers suddenly go from tin-can-and-string quality to something closer to what the artist actually intended. Got a pair of Sennheiser MOMENTUM 4 or ACCENTUM headphones? Good. They’re already prepped to milk this high-def goodness.
sennheiser-btd-700-laptop
Plug, Play, and Pretend Your Laptop Knows What It’s Doing
This dongle is class-compliant, meaning it sidesteps your device’s sorry excuse for Bluetooth like a pro, no complicated setup required—just shove it in like a flash drive and go. Android, iOS, Windows, MacOS? Doesn’t matter. Thanks to Bluetooth 5.4, your options suddenly multiply. Fire up an Auracast broadcast for that outdoor movie night, stream your favorite album in studio quality, or take a day’s worth of calls on the comfy Sennheiser MOMENTUM 4 headphones without sounding like a robot on a tin can.
Why It Matters: Key Features
  • Audiophile-Grade Codecs: aptX Adaptive and aptX Lossless crank your wireless sound up to 24-bit/96 kHz. Translation? No more excuses for “Bluetooth” sounding like a tinny mess.
  • Game Mode: A latency low enough (30 milliseconds) to keep your audio locked tight with the action—because watching a game where the sound arrives late is so last decade.
  • Auracast™ Support: Share your tunes (or lectures, if you must) with multiple Auracast-enabled devices at once. Party trick approved.
  • Crystal-Clear Calls: Finally, Bluetooth that actually makes you sound like a human on conference calls—no more “Can you hear me now?” moments.
sennheiser-btd-700-isofront-flat
How Does the Sennheiser BTD 700 Work with iPhones That Don’t Support aptX?
The BTD 700 acts as an external Bluetooth transmitter that handles the audio codecs itself—so even if your iPhone can’t natively do aptX (which is true for all iPhones, since Apple only supports AAC and SBC), the dongle will still send aptX Adaptive or aptX Lossless to your compatible headphones.
In other words: your iPhone sees the dongle as a USB DAC and sends standard audio to the dongle, which then encodes and transmits the audio to your headphones using the high-quality aptX codecs the iPhone alone can’t manage. This bypasses the iPhone’s codec limitations and upgrades your wireless sound quality without any fiddling.
So if you pair the BTD 700 with aptX-enabled headphones like the Sennheiser MOMENTUM series, you get all the benefits of aptX audio even on an iPhone that normally wouldn’t support it. It’s like giving your phone a secret audiophile upgrade card.
You can turn off your phone or tablet’s built-in Bluetooth and still use the Sennheiser BTD 700, since it operates independently of the device’s OS. You can also keep your AirPods connected via the native Bluetooth while your MOMENTUM 4 headphones pair with the dongle—letting you run two wireless audio connections at once without a fuss.
Comparison
BTD 600BTD 700
MSRP$39.95$59.95
Release DateJune 2022June 2025
SKU700248700434
ConnectivityBluetooth 5.2 compliant, class 1, 10 mW (max)Bluetooth 5.4 compliant, class 1, 10 mW (max)
Transmission frequency2,402 MHz to 2,480 MHz; GFSK, π/4 DQPSK / 8DPSK2,402 MHz to 2,480 MHz; GFSK, π/4 DQPSK / 8DPSK
Supported ProfilesHTP, A2DP, AVRCPHFP, A2DP, Auracast™
Supported codecsSBC,
aptX™,
aptX™ Adaptive
SBC,
aptX™,
aptX™ Adaptive
aptX™ Lossless,
LC3
Dongle / Adapter Weight1.9g / 2.8g2.2 g / 3 g
Dongle Size15.5 x 19.7 x 7.8 mm23.8 x 15.2 x 7.6 mm
Adapter Size15.5 x 25.3 x 7.8 mm25.69 x 15.2 x 7.6 mm
Supported operating systemsWindows 8.1 or later MacOS version 11 or laterWindows 10 or higher, Mac OS V11 and V12, Android 13 or higher, iPhone or iPad with USB-C
Storage TemperatureTemp: –25 to +70°C, Rel. humidity 10 to 90%Temp: –25 to +70°C, Rel. humidity 10 to 90%
App supportSennheiser Transmitter Updater (PC/Mac)Sennheiser Transmitter Updater / (PC/Mac)
sennheiser-btd-700
The Bottom Line
The Sennheiser BTD 700 is tiny, unassuming, and far smarter than the Bluetooth nonsense built into most devices—like a brilliant butler in a sea of bumbling fools. At 2.2 grams, it slips in unnoticed but immediately upgrades your audio to something your ears might actually enjoy. Plug-and-play means no brain cells wasted, and with premium codecs, low latency, and Auracast, it’s the only dongle that won’t make you question humanity. For under sixty bucks, it’s the kind of no-nonsense, elegant fix that makes you wonder why your laptop’s Bluetooth hasn’t been fired yet.
Price & Availability
The BTD 700 lands on June 3rd, 2025, priced at $59.95 USD / $69.95 CAD at sennheiser-hearing.com, and from select Sennheiser retailers. Your headphones will thank you—assuming they could talk, of course.
2 Comments
2 Comments
  1. Anton
    June 3, 2025 at 8:02 pm
    It’s interesting to me that Apple still refuses to play ball with everyone else in regard to Bluetooth codecs. Probably explains why I’ve never considered AirPods.
    • Ian White
      June 3, 2025 at 8:10 pm
      Anton,
      Apple will continue to do what it does until it’s not financially smart. Should Apple ever decide to end support for AAC, we will all dance if they take on aptX and its variants.
      Don’t hold your breath.
      IW
Ruark MR1 MK3 Desktop Speakers with iMac
Ruark MR1 Mk3 desktop speakers deliver high-res sound, versatile connectivity, and compact design. Add the RS1 subwoofer for deep bass without taking up space.
Nothing CMF Buds 2 Cases all colors Nothing CMF Buds 2 Cases all colors
Earbuds & In-Ear Headphones
Nothing’s CMF Buds 2 earbuds feature Dirac Opteo technology for superior sound clarity, deeper bass, and hybrid ANC—all in an affordable, durable package perfect...
beyerdynamic DT 990 PRO X Studio Headphones Lifestyle Woman Profile beyerdynamic DT 990 PRO X Studio Headphones Lifestyle Woman Profile
Beyerdynamic DT 990 PRO X adds detachable cable, 48-ohm impedance, STELLAR.45 drivers, and improved comfort—all for just $199.
Clearaudio Compass Turntables in Black and Silver with lid up front Clearaudio Compass Turntables in Black and Silver with lid up front
Discover the Clearaudio Compass, a German-engineered entry-level turntable built for audiophiles. Precision, style, and performance—ready to shake up Rega, Pro-Ject, and VPI.
Sennheiser BTD-700 with Momentum4 Headphones Sennheiser BTD-700 with Momentum4 Headphones
Dongle DACs
Pro-Ject Travel Set in Black and Silver Pro-Ject Travel Set in Black and Silver
Take real hi-fi on the road—no, not some tinny Bluetooth box. The Pro-Ject Travel Set is proper stereo, not sound for peasants. Fits in...
Father's Day Gift Guide 2024 Best Tech and HiFi Gifts
Upgrade Dad's digital lifestyle with gifts he'll enjoy all year and beyond this Father's Day. New Hi-Fi, Headphones, Home Theater and more!
The world's first headphones featuring DALI's patented Soft Magnetic Compound (SMC) technology. With 50mm custom drivers, active noise cancellation, aptX Adaptive Bluetooth and USB-C/3.5mm...
At $99, the ACCENTUM Open feature Bluetooth 5.3 multipoint connectivity to your devices while keeping you aware of your surroundings.
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
