Earbuds & In-Ear Headphones
Sennheiser Unveils ACCENTUM True Wireless Earbuds
At $199, the Sennheiser ACCENTUM True Wireless Earbuds aim to hit the sweet spot for sound quality, comfort and convenience.
Sennheiser ACCENTUM True Wireless Earbuds in white (2024 model)
Sennhesier has expanded its ACCENTUM headphone series with the addition of True Wireless noise cancelling earbuds for $199 USD, which feature an all-new ergonomic design and proprietary 7mm dynamic True Response Transducers.
Priced between Sennheiser’s CX Series and MOMENTUM True Wireless, the ACCENTUM TWS aim to offer unbeatable value, comfort, and convenience.
Man wearing Sennheiser ACCENTUM True Wireless Earbuds in white
Features
ACCENTUM True Wireless’ Hybrid ANC and Transparency modes lets wearers block or listen to ambient surroundings on-demand via simple tap gestures or Sennheiser’s free Smart Control app.
The app also enables further customizations with a 5-band equalizer and user-definable touch controls for managing media, phone calls, and voice assistants. A guided preset creator uploads to the cloud to allow access on all of your iOS or Android devices.
sennheiser-accentum-tws-white
​All of its capabilities are housed inside a completely unique take on earbud ergonomics; in a close collaboration with Sonova—a leading hearing aid manufacturer—thousands of ear models were analyzed to arrive at the ideal balance of stability, comfort, and sophistication.
The result of the collaboration is an innovative contour that complements a wide range of wearers in a singular form. The earbuds, still under the veil of secrecy, was a recent winner of the prestigious Red Dot Design award.
Four sizes of ear tips are included to further ensure a great seal for impactful low-frequency response and effective hybrid noise cancellation.
Advanced Bluetooth
Connecting ACCENTUM True Wireless to a smartphone goes beyond managing media and calls, thanks to Bluetooth 5.3. The earbuds are Bluetooth LE Audio and Auracast capable, for advanced connectivity to shared audio streams at Auracast-enabled museums, cafes, airports, and more in the near future. In addition to SBC and AAC codec support, the earbuds also utilize aptX and LC3 for maintaining dependable audio quality and long battery life.
Sennheiser ACCENTUM True Wireless Earbuds in black with charging case (2024 model)
Battery Life
ACCENTUM earbuds are rated for 8 hours of use on a single charge, and Sennheiser says the charging case can provide over 2 additional recharges for up to 28 hours of use together. In addition the case supports quick charging over USB, giving users up to 1 hour of playback in about 10 minutes. A USB-A to type C cable is included for convenience and the case supports Qi wireless charging.
As the third model in the ACCENTUM series, which includes ACCENTUM over-ear wireless headphones and ACCENTUM Plus,
Sennheiser ACCENTUM True Wireless, ACCENTUM, and ACCENTUM Plus Headphones
Left to right: ACCENTUM True Wireless, ACCENTUM over-ear wireless headphones and ACCENTUM Plus.
Price & Availability
​The Sennheiser ACCENTUM True Wireless earbuds are available in black or white colorways beginning May 21, 2024 for $199.99 at Amazon / $279.95 CAD.
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
With enhanced adaptive noise cancellation and a new driver design, Technics latest True Wireless Earbuds will give Bose, Sony and Sennheiser a run for...
At $279 or $399, the Beyerdynamic AMIRON 300 wireless ANC earbuds and AVENTHO 300 wireless over-ear headphones with ANC and head tracking are available...
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
At $449, the Noble Audio FoKus Rex5 wireless noise cancelling earbuds drop xMEMS support in favor of a new hybrid 5-driver array.
