Earbuds & In-Ear Headphones
Sennheiser ACCENTUM Open Earbuds: Situational Awareness and Clear Sound
At $99, the ACCENTUM Open feature Bluetooth 5.3 multipoint connectivity to your devices while keeping you aware of your surroundings.
Sennheiser Accentum Open Earbuds with case in black and cream
After dropping the ACCENTUM True Wireless Earbuds in 2024, Sennheiser’s back at it with the ACCENTUM Open. These are still true wireless earbuds, but with a twist—an open-ear design. So, while you’re enjoying your sound, you can actually hear the world around you. Because, you know, getting hit by a bus or shoved onto the subway tracks doesn’t really work as a selling point.
Situational awareness, people. It’s about not ignoring the world around you while you listen to your tunes.
From Friederike Menking, Product Manager: “ACCENTUM Open was designed to complement your busy life, not complicate it…Whether you are listening to music, catching up on a podcast at your desk, or checking in with your friends on your way to the train, the ease of use is second only to the sound.”
Sennheiser ACCENTUM Open Earbuds Black Lifestyle
Technology
The ACCENTUM Open packs an 11mm dynamic transducer positioned just outside the ear canal. This setup gives you a fit that not only cuts down on ear fatigue but also keeps you aware of your surroundings—because getting lost in your music without any clue about the world around you isn’t ideal. The design is simple and intuitive, no need for fancy ear tips or clips, just pop them in and go.
Quick note: Since these are open-ear earbuds, don’t expect noise-canceling features. The whole point is to let in ambient sound, so you don’t miss the important stuff, like a passing car or someone shouting your name.
As for the tech, the ACCENTUM Open runs on Bluetooth 5.3 with multipoint connectivity, meaning you can switch between devices without missing a beat. Jump from a work call on your laptop to your favorite playlist on your phone, all without the hassle. Plus, with dual-beamforming microphones, your call quality stays sharp, filtering out background noise so your voice comes through loud and clear.
accentum-open-earbuds-black
Comfort, Playtime and Waterproof Rating
Comfort and ease are key with the ACCENTUM Open. Each earbud weighs just 4.4 grams—about the weight of a playing card—so you barely notice them in your ears. They’re also easy to pop in and out when you need to, with a simple, ultralight stem that offers touch controls for quick adjustments.
As for playtime, these earbuds give you up to 6.5 hours on a single charge. When paired with the compact charging case, you’re looking at a total of 28 hours of use. And if you’re in a rush, just 10 minutes of charging via USB gives you up to 1.5 hours of playback—perfect for squeezing in a couple more episodes of whatever show you’re binging.
In terms of durability, the ACCENTUM Open is ready for whatever weather you’re facing with an IPX4 splash resistance rating. So whether it’s a light drizzle or you’re sweating it out at the gym, these earbuds are good to go.
Comparison
Sennheiser Accentum Open vs Accentum True Wireless Model
ACCEENTUM OpenACCENTUM True Wireless
Product TypeTrue Wireless EarbudsTrue Wireless Earbuds
Price$99.95$199.95
Wearing StyleOpen-Ear True Wireless Stereo EarphonesClosed-Ear True Wireless Stereo Earphones
Ear CouplingIn-ConchaEar-Canal
ConnectivityBluetooth 5.3 compliant, class 1, 10 mW (max) Bluetooth ClassicBluetooth 5.3 certified, class 1
Transmission (Freq/Modulation)2402 MHz to 2480 MHz; GFSK, π/4 DQPSK / 8DPSK2402 MHz to 2480 MHz. GFSK, π/4 DQPSK, 8DPSK
Supported ProfilesA2DP, AVRCP, HFPAVRCP, A2DP, HFP, TMAP, PBP
Supported CodecsSBC, AACaptX™, AAC, SBC, Auracast™ Broadcast Audio, LC3
Speaker TypeDynamicDynamic
Speaker Size11mm7 mm
Speaker Frequency Range25 Hz to 15 k Hz (@ 90dBSPL)5 Hz to 21 kHz
Speaker Sensitivity109 dB (1 kHz / 1 mW)107 dB (1 kHz / 0 dBFS)
Speaker THD<0,08% (1kHz / 94dB)< 0.08 % (1 kHz / 94 dB)
Speaker ImpedanceNot applicable (active BT headphones)Not applicable (active BT headphones)
Active Noise CancellationHybrid ANC technology
Microphone TypeMEMSMEMS
Mic Frequency Range100 Hz to 10 kHz100 Hz to 10 kHz
Mic Pick-up Pattern2 mics per earbud, beamforming for noise reduction2 mics per earbud, beamforming for noise reduction
Battery TypeBuilt-in Lithium-Ion rechargeable batteries/Earbud: 36mAh (MBT) / 35 mAh (VDL), Charging case: 400 mAhBuilt-in lithium rechargeable batteries: earbuds (R and L): 3.7 V DC-Symbol, 55 mAh, 0.204 Wh or 3.8 V DC-Symbol, 72 mAh, 0.274 Wh charging case: 3.7 V DC-Symbol, 400 – 420 mAh, 1.55 Wh max.
Battery LifespanUp to 6 hrs music playtime with earbuds/Up to 24 hrs overall music playtime with charging case (test condition: iPhone, mid volume level 85dB)8 hrs with the rechargeable battery of the earbud
28 hrs with the  rechargeable battery in the charging case
(test conditions: smartphone within 1 m distance, Bluetooth AAC codec, volume level 50 %, ANC off)
Charging TimeApprox. 1 hr for fully charged/After 10 min charging, 1 hr music playtimeApprox. 1.5 hours for full charge/Approx. 10 minutes for 1 hour of music playback
Power Supply5 V, 500 mA max/USB charging via USB-C socket at the charging caseUSB charging via USB-C socket:5 V DC-Symbol, 500 mA;
Wireless ChargingNot IndicatedQi Wireless Charging
Weather ResistanceIPx4, splash resistant (earbuds only)Splash proof (IP54)
Product Dimension (earbuds and charging case)51.77 x 50.18 x 25.36 mm 49.02 x52.07 x 28.96 mm
Product Weight38 g (both earbuds and charging case)
4.35 g (single earbud)
29.3 g (charging case)
52 g (both earbuds and charging case)
5.5 g (each earbud)
41 g (charging case)
Operating ConditionOperating Temp: 0 to +40°C
Charging Temp: 5 to 35℃/Rel. humidity 10 to 80%, non-condensing
Storage ConditionTemp: –20 to +60°C/Rel. humidity 10 to 90%Temp: –20 to +60°C/Rel. humidity 10 to 90%
ColorsCream, BlackWhite, Black, Blue
accentum-open-earbuds-cream
The Bottom Line
The wireless earbud market is flooded with options, and choosing the right pair is becoming more challenging than ever. The two main categories—In-Ear and Open Ear—each have their own strengths, but Open Ear models are gaining traction fast. While they don’t come with fancy noise cancellation features that shut you off from the world, Open Ear designs like the ACCENTUM Open offer situational awareness, keeping you in tune with your surroundings and adding a layer of safety for the listener.
At just $99.95, the ACCENTUM Open stands out in a crowded market. While you can find similarly priced closed-ear options from brands like SkullCandy, Edifier, and Final, or more affordable open-ear models from 1MORE (which throw in some noise cancellation for phone calls), Sennheiser’s reputation for sound quality and innovation makes this model a compelling choice.
In a sea of earbuds, Sennheiser’s ability to carve out a niche with the ACCENTUM Open is exactly what makes it worth considering.
Price & Availability
​ACCENTUM Open are available in cream or black for $99.95 at Amazon, but won’t ship until June 9, 2025.
The previously released ACCENTUM True Wireless are available now in black, blue or white for $199.95 at Amazon.
iFi Go Pod Air Wireless IEM Adapter Collage
At $249, the iFi GO Pod Air brings wireless hi-res audio to your IEMs without the weight of its predecessor. Same hi-res magic, now...
iFi Up Travel Bluetooth DAC iFi Up Travel Bluetooth DAC
Dongle DACs
Transform your travel audio from ‘meh’ to ‘oh wow’ with the iFi UP Travel. Hi-res Bluetooth, crystal-clear calls, and a design so sleek, you...
DALI V-16 F Subwoofer DALI V-16 F Subwoofer
DALI's flagship 16-inch subwoofer is a 1500-watt beast built to match its KORE and EPIKORE speakers, offering low distortion extension down to 18Hz.
We are Rewind GB-001 Boombox We are Rewind GB-001 Boombox
Rediscover retro cool with the We Are Rewind GB-001 boombox—Bluetooth-enabled, rechargeable, and built for modern mixtape lovers. Vintage vibes, modern tech, all in one...
PMC prophecy9 Speakers Lifestyle PMC prophecy9 Speakers Lifestyle
Discover PMC's latest Prophecy speakers at High End Munich 2025, showcasing cutting-edge technology, powered by the new PMC cor Integrated Amplifier.
NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
Mother's Day Gift Guide 2025 for Audio Video TV Lifestyle Projectors and Gadgets
Upgrade Mom's home audio and video experiences this Mother's Day with 10 gift ideas she'll absolutely love -- and you might too.
Dongle DACs
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PD10 DAP might replace your streamer.
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
At $299, the Bose Ultra Open Earbuds offer excellent situational awareness, support for Snapdragon Sound, and one surprising feature.
With an open-back design and wide frequency response, the Sennheiser HD 505 wired headphones aim to appeal to audiophiles and gamers.
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
