SD/HD-SDI to DVI Conversion is Simple with the 1T-C2-511 from TV One
The new addition to the TV One-Task line up is being demonstrated at IBC 2007.
Designed for broadcast and professional use, the new 1T-C2-511 SD/HD-SDI to DVI-I Converter provides a highly reliable conversion of HD-SDI signals to DVI-I, both digital and analog with reclocking and equalization of the input. HD-SDI HDTV resolutions from 720p to 1080i 60Hz are accommodated along with 525i or 625i SD-SDI signals, converting them to 480p and 576p respectively. The Embedded Stereo Audio can be extracted from the SD-SDI or HD-SDI input and any one of the eight available stereo channels may be selected and output in analog and AES3-id digital formats.
This compact and high-performance converter can handle Serial Digital Video Input up to 1.485Gbits/sec. The DVI HD output resolution matches the HD-SDI input. Housed in a Desktop metal case with the option of a Single/Dual Rackmount Kit, this easy to use product can be operated from the front panel or an RS-232 connection and an On Screen Display makes operation fast and simple.
The new 1T-C2-511 along with many other exciting products from TV One, will be on demonstration and display at the IBC 2007 Exhibition being held in Amsterdam between 7th and 11th September, so come along to our Stand 3.437 and see it in action.
Details of this exhibition and how to register for free can be found on the TV One website www.tvone.co.uk.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
