Screen Innovations Reference Motoroized II Projector Screen
Screen Innovations (SI), the leader in projection screen technology, recently announced the release of the Reference Motorized II screen, the most elegant motorized projection screen available today. The Reference Motorized II features an all new Electronic Solutions Inc (ESI) high speed motor with motor noise of only 3db over average home’s noise. One of the quickest motor speeds available today, you can quietly enjoy your home theater in less than 12 seconds!
The Reference Motorized II has eliminated the need for a flush mount chassis. Up until now, the industry standard has been selling a separate chassis to put the box in, which is both costly and impractical. With SI’s new Reference Motorized II, the installer can either add flush mount plates at the bottom or add the decor plate for external installation. Pricing remains the same either way, while eliminating the need for a second box.
Controlling and installing the Reference Motorized II is as quick and easy as its motor. New electronic illuminated set-top buttons eliminate the hassle of allen screws, making installation a snap. The Reference Motorized II’s new in-roller controls now “include” a 12 volt trigger, IR remote, and wall switch. RS232 & RF are available and are compatible with AMX, Crestron, Lutron and more. SI’s motorized projection screen mounting brackets give installers the flexibility to mount on-wall, on-ceiling, in-ceiling-top-mount, and in-ceiling-side-mount. This new design allows for incremental adjustment both vertically and horizontally after the screen is mounted.
“Reference Motorized II is the latest example of how SI is changing the projection screen landscape,” said Ryan Gustafson, president of Screen Innovations. “With the Reference Motorized II, we eliminated the need for a flush mount chassis and built the controls into the motor making it the fastest, quietest, and easiest motorized screen to install.”
The Reference Motorized II is available with many of SI’s HD screen materials, including the Gamma HD, Solar HD, Lunar HD, Gamma Maestro HD, and Lunar Maestro HD. Custom screen sizes are available in one inch increments and the unit comes standard with a 24 inch black screen drop (up to six feet with custom orders).
The Reference Motorized II is available now.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
