iPhone Apps
Scosche switchBACK surge g4 Battery Case for iPhone
Scosche has introduced the switchBACK surge g4 (model IP4BAT), a backup battery and kickstand case for iPhone 4. Its integrated kickstand and an internal 1800mAh lithium-ion battery, capable of charging a dead iPhone 4 up to 80% full, make the switchBACK surge the ideal case for power intensive applications like FaceTime and watching videos. Scosche's accompanying, free reVIVE app provides detailed battery information so users know exactly how much juice they have left.
Four blue LED lights indicate the surge's battery life and the included micro-USB cable allows for easy recharging and synching the iPhone 4 with the case on. The case will provides an additional 275 hours of standby, up to 12 hours of talk time, up to 36 hours of audio, up to 9 hours of Wi-Fi, or up to 9 hours of video.
The Scosche switchBACK surge g4 come with two interchangeable polycarbonate backs (Gloss Black & Metallic Silver), is compatible with both the AT&T Verizon iPhone 4 models, and is available now for $79.99.
Buy direct from scosche.com – use promo code TECHHEAD for 20% off
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
