Scosche reviveLITE II iPhone/iPod Charger and Nightlight
Second generation docking charger features USB port to simultaneously charge two devices
Scosche Industries just announced the availability of its reviveLITE II. The second generation iPod/iPhone charger and nightlight has a smaller footprint than the original model and was redesigned to offer greater stability when plugged into an outlet.
Scosche also added a USB Port to the reviveLITE II, so users can charge another USB powered device while powering up their iPod or iPhone. Like the original reviveLITE, the new version provides travelers with a switchable LED nightlight to avoid stubbing a toe in an unfamiliar hotel room.
“Scosche products are designed to eliminate clutter and enhance the accompanying device,” said Kas Alves, executive vice president of Scosche Industries. “reviveLITE II does just that, providing a docking charging solution for the iPod or iPhone and allowing travelers to eliminate the need for carrying a second charger for another USB powered device.”
The reviveLITE II is available now at www.scosche.com for $24.99 MSRP and will be available in major retailers this spring.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
