Schiit Audio’s Vali 3 Hybrid Headphone Amp and Preamp Can Be Your Desktop Hi-Fi Hub
With 100V on the plate, Schitt claims its Vali 3 tube headphone amp and preamp beats everything they’ve tested up to $2,799, for only $149.
Schiit Audio Vali 3 Tube Headphone Amp
Schiit Audio faces a lot more competition in 2024 from brands like Topping, FiiO, Cayin, and Questyle — but there is no question that its customer base has remained rather loyal. And why would they leave? They offer excellent Schiit for the money.
Case in point — the brand new Schiit Vali 3 Hybrid Headphone Amplifier and Preamp for only $149 USD.
Schiit Audio Vali 3 Hybrid Headphone Amp and Preamp Tube Close-up
The Vali 3
The Vali 3 tube hybrid headphone amp and preamp is an improvement from the previous generation Vali 2++. Major improvements include:
  • 100V on the tube plate (over 50% higher than before), rather than 60V, for increased linearity and gain
  • Topological improvements that lower overall feedback and maintain performance
  • A new optimized layout with better signal flow and ergonomics
  • All-new attractive advanced-form USA-stamped custom chassis
  • Massively improved ventilation and lower operating temperatures
Schiit Audio Vali 3 Hybird Headphone Amp and Preamp Rear
The Vali 3 is designed to be ready to tube your entire desktop—delivering plenty of power for hard-to-drive headphones, and a low noise floor for more sensitive cans.
In addition to its built-in headphone amp (a ¼ front panel headphone output is provided), the Vali 3 includes RCA inputs for an additional source, and preamp outputs that can be used to connect to powered speakers and speaker monitors, and home audio systems.
With a familiar Schiit cabinet design, the Vali 3 stacks perfectly with Modi DACs or Loki Mini equalizer.
Schiit Audio Vali 3 Hybrid Headphone Amp and Preamp With Dan Clark Headphones
Tech Note: The Vali 3 ships with a 6N3P tube standard for great stock sound. However, for even better performance, users can also use the 5670/2C51, ECC42, CV4013, and the classic WE396A.
Specifications
  • Maximum Power at 32 ohms: 1500mW RMS per channel
  • Maximum Power at  50 ohms: 1000mW RMS per channel
  • Maximum Power at 300 ohms: 400mW RMS per channel
  • Maximum Power at 600 ohms: 200mW RMS per channel
Note: Maximum power rated at less than 10% THD for tube and tube hybrid amps, as compared to less than 1% for solid state.
Low Gain
  • Frequency Response:
    • 20Hz-20Khz, +/-0.02db at 300 ohms
    • 20Hz-20Khz, +/-0.6db at 32 ohms
  • THD: <0.007%, 20Hz-20KHz, at 1V RMS, 300 ohms
  • IMD: <0.014%, CCIR, 300 ohms
  • SNR: >117db, A-weighted, referenced to 2V RMS
  • Crosstalk: -87dB, 20Hz-20KHz, 300 ohms
  • Output Impedance: 0.5 ohms
High Gain
    • 20Hz-20Khz, +/-0.04db at 300 ohms
  • THD: <0.35%, 20Hz-20KHz, at 1V RMS, 300 ohms
  • IMD: <0.45%, CCIR, 300 ohms
  • SNR: >105db, A-weighted, referenced to 2V RMS
  • Crosstalk: -70dB, 20Hz-20KHz, 300 ohms
  • Output Impedance: 1.8 ohms
Schiit Audio Vali 3 Hybrid Headphone Amp and Preamp Inside
Additional Specifications
  • Input Impedance: 50K ohms
  • Gain: 5 (14dB) or 1 (0dB)
  • Topology: Coherence™: tube voltage gain with convolved bipolar current mode inverter and discrete bipolar class A driver and Class AB output stage
  • Protection: delayed start and fast shut-down with muting relay
  • Power Supply: wall wart with 24VAC and 6VAC outputs, regulated HV and LV rails for tube and bipolar components, 6V AC heater
  • Power Consumption: 9W
  • Size (WDH): 5 x 3.5 x 2.75-inches
  • Weight: 1 lb
From Jason Stoddard, co-founder of Schiit Audio: “We’ve just blown up the entry-level tube scene,…I mean, there is no more entry-level. Vali 3 uses the same tube rail as much more expensive amplifiers, and it does it without compromise—no switching supplies, no giant chassis, no extreme heat, no big price tag.
Schiit Audio Vali 3 Hybrid Headphone Amp and Preamp Black Front Angle
Price & Availability
Vali 3 is priced at $149 at schiit.com and Schiit Audio Retail Store in Newhall, California
Tip: The Vali 3 is made in the USA. Most components, including chassis and PC boards, are made by US companies in the USA. Wall-wart transformers are made in China. All assembly, QA, and testing, including 100% instrumented test and 100% listening test, are done at Schiit’s Corpus Christi, Texas facility.
4 Comments
4 Comments
  1. ORT
    March 29, 2024 at 7:11 pm
    Nice. Not good looking enough for me but I am shallow that way, but the Vali 3 is Schitty-Pretty and that is NOT damning it with faith praise.
    Audio enthusiasts vuew the hobby as a way of life. And the frAudiophiles?
    A way of strife.
    Listen to the music, not the equipment.
    ZatORTichi
    • Ian White
      March 29, 2024 at 8:21 pm
      Lord ZatORTichi,
      I do like the new top panel with the petal design.
      Excuse me while I go sharpen my sword. Incoming hate emails…
      Lord YojimboBerg
      • ORT
        March 30, 2024 at 2:49 pm
        Dōmo arigatō, Iansan. 🙂
        ORTofon 😉
    • Alexander Dydula
      July 11, 2024 at 12:15 pm
      Totally agree!
      Listen to the music while you can!
      Alex
Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Focal Bathys MG Wireless Headphone in-hand Focal Bathys MG Wireless Headphone in-hand
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Craft Recordings announces seven titles coming to participating independent music retailers on Record Store Day, April 12, spanning jazz, salsa, rock and soul.
DAPs
At $2,299, Astell&Kern found a few ways to maintain flagship audiophile DAP performance at a lower cost. Find out what's changed.
Daily Deals
Spring time is here and with it the opportunity to bring home a giant TV at a great price to enjoy all the basketball...
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Is it possible to make Hi-Fi and home theater work in really small spaces? EIC Ian White's journey into the great unknown of cabin...
