Schiit Audio’s Balanced Kara Preamp and Headphone Amp Offers an Alternative to the Freya S
Priced at $699, Kara is a fully discrete, solid state preamp with a headphone jack.
Schiit Audio Kara Nexus Preamp and Headphone Amp - Front View
If you’re going to offer an alternative to consumers, it better offer improved functionality, superior sound quality, and a price that makes sense when you have so many other options in your existing lineup. Unlike the new Schiit Audio Mjolnir 3 which will only be available as a limited run product until everything is sold out, the new Schiit Audio Kara is sticking around.
The $699 balanced solid-state preamp/headphone amp offers an alternative to the extremely affordable Schiit Freya S with some key differences. Kara utilizes a 48VA transformer (24VA transformer on the Freya S), offers an easier to use front panel, and is said to offer better performance.
In addition, the Kara is also quite different than the Freya+ preamp. If you want a tube preamp with a lot of flexibility (including differential buffer mode, and the ability to run LISST solid-state tubes), that’s your preamp. Otherwise Kara costs less, doesn’t use tubes that wear out, and gives you a headphone jack.
The Schiit Audio Kara can also be used as a passive pre-amplifier for those who want that option.
Features and Specifications
Nexus technology. This incorporates current feedback with nested differential stages; discrete summed single-ended outputs with high-current headphone capability; intelligent headphone oversight and protection.
Schiit Audio Kara Nexus Preamp and Headphone Amp - Rear View
  • Input Impedance: 10K ohms
  • Output Impedance: 75 ohms SE, 600 ohms balanced
  • Crosstalk: >110dB typical all modes
  • Inputs: 2 XLR pairs plus 3 RCA pairs, selectable via front switch or remote
  • Outputs: 1 XLR pair plus 2 RCA pairs, selectable via front switch or remote
  • Headphone Output: Front panel plug-in (
  • Volume Control: Relay-switched stepped attenuator with discrete thin-film resistors, 128 0.625dB steps
  • Operational Control: In addition to onboard controls, the Kara also comes with a wireless remote.
  • Power Supply: One 48VA transformer with dual series regulated +/-32V rails with Quietude topology; plus regulated 5VDC for microprocessor
  • Power Consumption: 22W typical
  • Dimensions (WDH): 16 x 8 x 2 – inches
  • Weight: 11 lbs
Specifications
Balanced to Balanced
  • Gain: 1 (0dB)
  • Frequency Response: 20Hz-20Khz, -0.1db, 3Hz-500KHz, -3dB
  • THD: <0.0002%, 20Hz-20KHz, at 4V RMS
  • IMD: <0.0002%, CCIR
  • SNR: >129db, A-weighted, referenced to 4V RMS
  • Gain: 4 (12dB)
  • Frequency Response: 20Hz-20Khz, -0.1db, 3Hz-300KHz, -3dB
  • THD: <0.0004%, 20Hz-20KHz, at 4V RMS
  • IMD: <0.0004%, CCIR
  • SNR: >123db, A-weighted, referenced to 4V RMS
Balanced to SE, x1 Gain
  • THD: <0.0003%, 20Hz-20KHz, at 2V RMS
  • IMD: <0.0003%, CCIR
  • SNR: >123db, A-weighted, referenced to 2V RMS
SE to Balanced, X1 Gain
  • THD: <0.0015%, 20Hz-20KHz, at 4V RMS
  • IMD: <0.0022%, CCIR
  • SNR: >122db, A-weighted, referenced to 4V RMS
Headphone, X1 Gain
  • Maximum Power, 32 ohms: 1W RMS per channel
  • Maximum Power, 300 ohms: 1W RMS per channel (yes same as 32 ohms)
  • SNR: >123db, unweighted, referenced to 2V RMS
  • Crosstalk: >-90dB
  • Output Impedance: 0.25 ohms
Schiit Audio Kara Nexus Preamp and Headphone Amp - Inside View
Price and Availability
The Kara is available for $699 at schiit.com or at the Schiit Audio Retail Store in Newhall, California. It includes a 5 year warranty with a 15-day money-back guarantee (5% restocking fee applies).
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
At $1,999, Orchard Audio Valencia is a balanced desktop power amplifier designed for headphones, but powerful enough for speakers.
North American audiophiles can now experience Leema Acoustics’ Welsh-made hi-fi components.
At only $279, the Schiit Saga 2 Preamplifier claims to be the best volume control in the world.
With 100V on the plate, Schitt claims its Vali 3 tube headphone amp and preamp beats everything they've tested up to $2,799, for only...
The summer heat has been raging but we're ready to sweat about the Schiit Audio Bifrost 2/64 and Lyr+ which were just announced.
Although not new in 2023, the Bryston BHA-1 has become our favorite headphone amplifier under $2,500.
No DSD. No MQA. Just the best possible 24-bit/192kHz PCM DAC they can make. The Schiit Yggdrasil+ MIB is upgradable and $2,599 USD.
Naim Audio makes a very subtle visual change to its 500 Series of high-end audio components as of October 2023.
