Sceptre X505BV-FHD LCD HDTV Announced
Sceptre introduced the budget-price, 50-inch X505BV-FHD LCD HDTV with SRS TruSurround HD sound, which optimizes bass performance to create a vivid 3D sound experience. In addition, it comes with multiple HDMI ports for easy connectivity, a USB port to easily view and access music and JPEG files, the ability to swivel up to 30 degrees to adjust to any viewing angle, and more.
Sceptre X505BV-FHD 50-inch LCD HDTV
To complement the crisp images, sound quality and features of the 50-inch LCD HDTV, Sceptre designed the 50-inch LCD HDTV to be energy efficient, resulting in long term cost savings for the consumer. According to the Energy Star rating, the 50-inch LCD HDTV has an estimated $21 in estimated yearly cost, lowest in its class.
Price and Availability
The Sceptre X505BV-FHD 50-inch LCD HDTV is currently available for $999.99.
Specifications
  • Model: X505BV-FHD
  • Active Screen Size: 50″
  • Aspect Ratio: 16:9 Wide Screen
  • Brightness: 350 cd/m2
  • Resolution: 1920 x 1080
  • Response Time: 8 ms
  • Built-in TunerATSC / NTSC / Clear QAM
  • Signal Compatibility: 1080P, 1080i, 720p, 480p, 480i
  • HDMI Input Support: 1080/24p, 1080p/60p, 1080i, 720p, 480i
  • LCD Lamp Life: Over 50,000 hours
  • Ports: 3 HDMI, 1 USB
  • Energy Star (V5.3)
  • Auto Dynamic Contrast Enhancement
  • Automatic MPEG Noise Reduction
  • Surround Sound with Sound Equalizer
  • Neck & Base Detachable
  • Swivel Angles +/- 30 degrees
  • Wall Mountable (400x400mm)
  • Weight: 49.38 lbs. (with stand)
See more HDTVs.
Michell Audio Apollo Phono Preamplifier and Muse Power Supply
Does the Michell Audio range of high-end turntables finally have a complementary phono pre-amplifier to match its capabilities? The Michell Apollo looks ready to...
Optoma Photon Go UST Projector Black Optoma Photon Go UST Projector Black
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Shanling EH2 Headphone Amplifier and DAC Shanling EH2 Headphone Amplifier and DAC
Forte Distribution previews Shanling's $399 EH2 DAC Headphone Amp for CanJam Attendees
FiiO FT7 Open-back Planar Magnetic Headphones Angle FiiO FT7 Open-back Planar Magnetic Headphones Angle
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
WiiM Vibelink Amp Lifestyle WiiM Vibelink Amp Lifestyle
WiiM is well-known for its streaming products, but they are expanding their reach with a dedicated integrated amplifier.
Meze Audio POET Headphones on Table with Cable Meze Audio POET Headphones on Table with Cable
Earbuds & In-Ear Headphones
Smaller, lighter, and more affordable than the flagship Empyrean II, the $2,000 Meze Audio Poet have planar magnetic fans rather excited.
Ultimate Man Cave Gift Guide 2025
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
