Sceptre E325BV-HD LED LCD HDTV
Sceptre introduced the E325BV-HD 32-inch LED LCD HDTV, a blend of high performance, modern design and affordability. Encased in a ultra light chassis weighing only 20 lbs with stand, this TV provides 1366×768 resolution and 6.5ms response time. In addition, it swivels up to 30 degrees, is neck and base detachable, and wall mountable, making it versatile enough to double as a computer monitor or digital signage. Also Sceptre claims superb energy efficiency with an estimated yearly energy cost of only $11.
Equipped with 3 HDMI ports, a USB port and a headphone jack, the new LED HDTV allows users to quickly and easily share pictures, listen to music or even connect their laptops. The unit also features 2×10 watt built-in speakers and multiple features to maximize audio quality, including noise reduction filer, surround sound mode, sound equalizer settings and auto volume level control
Price and Availability
The Sceptre E325BV-HD 32-inch LED HDTV is currently available online at Wal-Mart for $329.
See more about: LCD HDTV, LED HDTV, Sceptre, HDTV
1 Comment
1 Comment
  1. Bob Smetters
    June 18, 2014 at 9:14 pm
    Bought three Scepters… two of them went dead in two years, waiting for the third to die… Don’t buy unless you don’t mind replacing TV’s every couple of years… they are getting hard to throw out.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
