HDTV 4K & 8K TV
Sceptre E320GV-FHD LED HDTV
Sceptre introduced a new line of 32-inch nickel brush LED HDTVs. Part of the Galaxy series, the new HDTVs feature a nickel brush design, elegant power indicator, are available in different color schemes, and feature cutting-edge technology that will entertain in style.
Sceptre E320PV-FHD LED HDTV
Highlighted by an elegant combination of contrasting textures, a front bezel and a beveled stand, the new line of 32-inch FullHD 1080P LED TVs provides a futuristic aura to any décor in any setting. Measuring only 1″ at its thinnest and 1.82″ at its thickest, the new FullHD 1080P TVs are slim enough to fit into any space in any room, while the 1080P and 1920×1080 resolution makes it versatile enough to enjoy your favorite HD movies or use it as a gaming monitor.
The new line of 32-inch FullHD 1080P LED TVs come standard with 3 HDMI ports for easy connectivity, a beveled tempered glass stand swivel base, 16:9 widescreen aspect radio, 50,000:1 Dynamic Contrast Radio and two 9 Watt speakers with 7-Band equalizer for immersive sound experience.
Sceptre E320BV-FHD LED HDTV
Specifications
  • 31.5″ active screen size
  • 1080P HDTV
  • 1920×1080 Resolution
  • 60Hz Refresh Rate
  • 16:9 Widescreen Aspect Ratio
  • 400 cd/m2 Brightness
  • 50,000:1 Dynamic Contrast Ratio
  • 3 x HDMI Ports
  • 6.5 ms Response Time
  • ATSC/ NTSC/ Clear QAM
  • 9 Watt x 2 Speakers
  • Wall Mount Patter 200 mm x 100 mm
  • Beveled tempered glass stand
  • Swivel Base
Models
  • E320GV-FHD (Nickel Brush with Black Accent) → $499
  • E320BV-FHD (Black with Nickel Brush Accent) → $499
  • E320PV-FHD (Pink with Nickel Brush Accent) → $499
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
