Scandyna Minipod Mk II Bookshelf Speakers
Scandyna introduced the Minipod Mk II bookshelf speaker, an update to the original Minipod first introduced over 20 years ago, with improved drive units and crossover. While the Minipod Mk II looks the same as the original, the mid/bass driver has been re-designed and now features a new 4-layer aluminium voice coil to improve efficiency. The crossover has been upgraded to incorporate the new driver and, to make use of the improved bass response, the crossover point had been changed down to 2700Hz from 3000Hz. These new enhancements mean that the Minipod Mk II carries on with the same wow factor for its ergonomic design and sound quality that it was always famous for.
The Minipod originated in the UK during the 1990’s, and was originally manufactured by Bowers & Wilkins Loudspeakers. Scandyna, a Danish Loudspeaker manufacturer owned by Peter M Hasselriis, has manufactured the Minipod since 1999. Scandyna has continuously developed new products; all following the same ‘form follows function’ design philosophy of the Minipod. The brands striking curved designs are engineered to reduce the unwanted reflective internal sound waves that can ruin a loudspeaker’s performance.
All Scandyna products are developed and engineered in high-tech factories in Denmark and designated OEM manufactures in China.
Specifications
  • Colors: Red, White, Black, other colors available to special order
  • Shape: 2 way bass reflex, abs cabinet
  • Frequency: 55 Hz to 25 KHz
  • Sensitivity: 91 Db for 2.83V / 1 meter
  • Drive Units: 1 x 100mm Kevlar mid/bass driver
  • Tweeter: 1 x 19mm soft dome
  • Weight: 1.8 kg
  • Dimensions: 157 x 256 x 325mm (width, height, depth)
  • Accessories: Spikes, wall bracket and stand.
Price and Availability
The Minipod Mk II is available now in three standard colors – black, red or white for £549 / £585 without/with spikes in the UK. Also check Amazon.com or Amazon.co.uk.
Exclusive Review: We reviewed the original Minipods way back in 2003.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Hands-on review of the Bowers & Wilkins Pi6 In-ear True Wireless Earbuds covers sound quality, ANC performance and more.
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
Our favorite true wireless earbuds of 2024 include two noise cancelling earphones from Bose and Sennheiser at different prices points.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
