A/V Furniture & Accessories
Satechi ST-A1500 HD Digital Indoor Flat Amplified TV Antenna Announced
For those needing over-the-air high-definition local TV reception, Satechi introduced the HD Digital Indoor Flat Amplified TV Antenna (ST-A1500). The USB-powered antenna would work best on a HDTV with a USB port for power, otherwise you'll need to use a USB power wall adapter.
The HD Digital Indoor Flat Amplified TV Antenna makes HDTVs compatible with the new digital broadcasting format now being offered by television stations. The antenna comes equipped with hardware that provides the stable reception this new format requires along with improved antenna matching, which provides optimum performance for the television's transmitter output circuit. Additionally, the antenna's low noise amplifier (LNA) provides the best digital reception available.
The HD Digital Indoor Flat Amplified TV Antenna easily connects to your television with a coaxial cable and receives power for the amplifier through the USB power cord. The included wall mount keeps the unit unobtrusive and additional features, such as UHF/VHF reception, make it a powerful addition to anyone's living room.
Satechi ST-A1500 HD Digital Indoor Flat Amplified TV Antenna under HDTV
Price and Availability
The Satechi HD Digital Indoor Flat Amplified TV Antenna is available now for $34.99. See more antennas.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
