Camcorders
Sanyo Xacti HD1010 Camcorder Announced
SANYO Full HD Camcorder Has ‘Face Chaser’ Technology for Video and Stills; Features Slow-Motion Video Mode and 7-fps Sequential Shooting
SANYO, a world leading digital camera manufacturer, debuts the Xacti HD1010, an ultra-compact, full 1920 x 1080 (1080i) high-definition digital camcorder featuring “Face Chaser” face detection technology for both video and stills, plus a new slow-motion video mode and seven frames-per-second sequential shooting for superb action photography. The sleek and simple-to-use HD1010 takes 4-megapixel digital still images and records video and stills to convenient SD memory cards or SDHC cards (sold separately) up to 32GB.
The SANYO Xacti HD1010 will be available in the U.S.A. in July 2008 at an MSRP of $799.991.
“The SANYO Xacti HD1010 is our second-generation Full HD camcorder and offers a full complement of innovative features such as automatic ‘Face Chaser’ face detection for both video and stills, along with improved image processing for even better image quality2,” said Tom Van Voy, Vice President and General Manager of SANYO’s Audio Video Division. “The HD1010 offers advanced, high-definition video performance and high-quality stills in one small, lightweight device.”
Face Detection/Face Chaser Technology
The latest in digital still photography — Face Detection and Face Chaser technology actually monitor the subject’s face and adjust brightness and focus to incredibly clear photos. This technology can be used to recognize up to 12 faces at a time in both video and still photos.
Slow-motion Video Mode
For great sports videos and many other fast-action video projects, the HD1010 can record video at 300 frames-per-second3 to produce smooth, super slow-motion 60fps video playback.
7 Frames-per-second Sequential Shooting
Shoot digital still images like the pros with up to seven photos in a single second. Ideal for special effects or action photography.
Small and Light Full HD Camcorder
The HD1010 weighs only 9.9 ounces (with battery and SD card). It incorporates advanced MPEG-4 AVC/H.264 video compression, enabling up to approximately 87 minutes of Full HD (1920 x 1080) video recording on an 8GB SDHC memory card (sold separately).
Wide Dynamic Range Mode
Wide Dynamic Range Mode allows improved images in varying degrees of light and shade.
Four Megapixel Digital Images
The Xacti HD1010 enables simultaneous shooting of 4-megapixel still images and HD movie clips, with a simple press of the shutter button during the recording of a video clip. Users need never miss another precious photo opportunity. (Depending on the mode used to take still images, simultaneous video clip shooting may be interrupted. While shooting video clips, using the digital image stabilizer may change the angle of view for still images.)
Comfortable Ergonomic Design
The HD1010 is designed for easy, one-handed operation with “one thumb” operation of all key functions. The camcorder is comfortable to hold, even for extended periods.
Full 1080i HD Sensor
Incorporating the latest high-definition CMOS sensor, the SANYO Xacti HD1010 captures full 1080i high-definition video (1920×1080) at 60 frames-per-second. Designed to record the rich and vibrant colors of real life, the HD1010 also captures subtle tones to provide a natural-looking result. SANYO’s latest high-speed image processing engine capably handles the high capacity demands of Full HD data. Signal processing has been optimized for gamma correction and noise reduction, improving lens color-sensitivity and image quality when filming in darker locations. In addition, the video codec algorithm has been adjusted from 12 to 14 Mbps to allow more data per second, for improved imaging.
10x Optical HD Zoom Lens
At the front of the HD1010 is a commanding 10x all-glass HD lens. The camcorder’s fast f/1.8-2.5 lens is capable of allowing almost four times more light through to assist in lower light venues. Consisting of eight groups and eleven total lenses with a built-in neutral density filter, the HD1010’s lens provides a spectacular field-of-view with a 38-380 mm range (35 mm equivalent).
Image Stabilization
High-definition can’t hide shaky or erratic camera movement. So, SANYO’s HD1010 comes with a sophisticated image stabilizer for both stills and video. This handy feature operates in both wide-angle and telephoto modes, giving every shot a solid, professional-looking feel. Image stabilization allows for clear pictures of the subject even when moving or rotation occurs.
Large 2.7-inch Widescreen Display
The HD1010 features a large 2.7 inch widescreen Liquid Crystal Display (LCD). The display flips out from the camera and rotates up to 285 degrees on axis, allowing you to take great video or still images even from difficult-to- view positions, which is especially useful when shooting in large crowds or in small rooms.
HDMI High-definition Output
It’s easy to view and share high-definition video on your HD television with the HD1010. Using the HDMI (High-Definition Multimedia Interface) terminal built into the base station, just one cable connects your camcorder to your TV for a totally digital output. HDMI carries both the video and audio signals in digital form for the highest quality playback.
Easy Camera to PC Connection
SANYO’s HD1010 streamlines the confusing and complicated component connection process with an innovative docking station. This dock provides instant connectivity via HDMI cable (sold separately), component, composite or S-video connection to a TV, DVD player and computer. The HD1010 even recharges its internal battery when nested in the docking station.
Records to Convenient SD/SDHC Memory Cards
The SANYO Xacti HD1010 records high-definition and photos directly to a standard SD or SDHC Memory Card. The camcorder is capable of recording up to 87 minutes of 1080i high-definition video on a single 8GB card (sold separately). When connected to a computer via the USB cable, the HD1010 acts as a standard card reader. Transferring images and videos to your computer has never been easier.
Xacti-HD1010
Addition HD1010 Features:
  • Random Access: Each video is recorded as an individual MPEG-4 and each still as a JPEG so you can have true random access allowing you to review a specific image or video quickly and easily, without waiting for tape rewinding or fast forwarding.
  • Super-fast Startup: With its tapeless design, the HD1010 eliminates the need to queue up a tape deck or get a DVD or hard drive spinning, allowing the camcorder to begin shooting in as little as two seconds! When the HD1010 is powered on, closing the LCD display puts the HD1010 in standby mode. Simply open the display and the camcorder automatically powers up and can begin recording virtually instantaneously.
  • Equipped with ‘SIMPLE’ mode so even beginners can create high quality, beautiful high definition movies
  • New 1920 x 1080, 30 fps mode allows further possibilities with Full HD and computers (when in Full-SHQ 30 fps/12 Mbps mode)
  • Features 2.7 inch 230,000 pixel, widescreen TFT-LCD monitor, ideal for viewing HD footage
  • Wind Roar and Red Eye Reduction
  • Web Cam function
  • Built-in, pop-up flash
  • A variety of manual controls are available for versatile, advanced shooting. These include manual focus adjustment (16 settings); aperture adjustment (6 stops); exposure compensation (1.8 EV, 0.3 EV steps); shutter speed (13 settings); and image-quality adjustment (for sharpness and color saturation)
  • Bundled with “Nero 8 Essentials for SANYO” for easy playback and editing
  • Uses included, long-lasting 1900 mAh Lithium-ion battery (DB-L50)
  • Compatible with a variety of optional accessories using cold shoe mount, such as external strobe, video light, microphone, etc.
  • Optional adapter lenses available: telephoto, wide-angle and semi-fisheye
  • Continuous Still Image Shooting function – 7 frames per second4
  • Able to take still pictures while in the middle of Full HD movie recording5
  • 9-image quick display function
  • In-camera editing
  • 48 kHz, 16-bit, 2-channel sound
  • PictBridge compatible
  • Headphone Jack
About SANYO
SANYO Electric Co., Ltd. is a multi-billion-dollar global leader in providing solutions for the environment, energy and for lifestyle applications based on its Brand Vision ‘Think GAIA’. SANYO Fisher Company (a division of SANYO North America Corporation, a subsidiary of SANYO Electric Co., Ltd.), based in Chatsworth, California, markets digital still cameras, digital media camcorders, digital projectors, home appliances, security video equipment, audio systems, portable and mobile electronics and HD televisions.
All products and trademarks are the property of their respective owners. Because its products are subject to continual improvement, SANYO reserves the right to modify product design and specifications without notice and without incurring any obligations.
  1. Manufacturer’s Suggested Retail Price. Pricing subject to change at any time. Actual prices are determined by individual dealers and may vary.
  2. Compared to the SANYO Xacti VPC-HD1000
  3. Still images and zoom can not be used simultaneously with ‘slow-motion’ filming. Focus/exposure and digital image stabilization not available in this mode. For this model 300fps is actually 299.7fps
  4. Recorded as 4.0 Mega-pixels
  5. Recorded as 2.0 Mega-pixels
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
