Sanyo PLC-WL2503 LCD Projector
SANYO announced today the introduction of a wide XGA ultra short-throw 3 LCD interactive projector geared for the educational and corporate presentation markets that provides full functionality regardless of the surface on which the image is projected. Unlike existing interactive solutions that require whiteboards or other surfaces with built-in sensors, the PLC-WL2503 operates when any screen or wall surface is used to display the projected image. 2,500 lumens brightness and a 500:1 contrast ratio ensure picture quality and clarity, and an ultra-short throw lens creates images from 60 to 110 inches at a distance of no more than 47 inches from the screen. Available in January 2011, the PLC-WL2503 has an MSRP of $1,695.99.
Conventional interactive projector systems require the use of an interactive whiteboard connected to the PC. SANYO's interactive system eliminates this need by providing two interface devices (a pen and a pointer), each containing an infrared (IR) transmitter. When the tip of either device is pressed against the screen or wall surface, it generates an IR signal that is detected by a camera module located on the front surface of the projector. This signal allows the system to determine the relative location of the tip on the projected image, and this information is transmitted to the PC through a USB connection for display on screen. Calibration for setup is considerably simpler than competing projector systems, requiring only half of the calibration points. The system is compatible with virtually all software, as well as the Windows 7, Vista, XP and Mac OS operating systems.
With an ultra short-throw lens, the PLC-WL2503 can create an 80-inch projected image from a distance of only 34-inches. The ability to locate the projector so close to the projection allows presenters to work next to the screen without casting shadows or having to avoid the projector's light beam. Its Wide XGA format provides a 16:10 aspect ratio with 1280×800 resolution, allowing the presentation of HD resolution images, and an HDMI 1.3 input facilitates connection to HD sources and DVD players. When the projector is used with a surface other than a conventional screen, special modes are available for blackboard and color board surfaces.
Demonstrating SANYO's understanding of the importance of minimizing maintenance time and cost, the projector can operate up to 4,000 hours before requiring a lamp or filter replacement. SANYO's proprietary hybrid filter uses multiple filter stages, with each layer capturing smaller particles than the previous one, ultimately providing six times the area and 15 times more dust collection than conventional projector filters, resulting in longer filter life and lower operational costs. When lamp replacement is necessary, access is facilitated through a top panel access door.
Sanyo PLC-WL2503 LCD Projector - Remote
The PLC-WL2503 uses SANYO's exclusive PJ Network interface for control and status reports. Through a wired LAN control and a web browser, the projector can be switched on and off, inputs can be selected, and system status reports, including the need for lamp replacement, can be sent by email to up to ten addresses. Control ports include a D-sub 9 RS-232C connector and an RJ-45 connector for the wired LAN Network control
Video inputs include an HDMI 1.3 terminal and dual D-sub 15 connectors, one used for Component video and the other providing dual functions, either as an input or as an analog RGB output. Also provided are S-Video and RCA composite inputs. Audio inputs include a stereo pair of RCA connectors and a stereo mini jack. Variable audio output is available through another stereo mini jack connector. A high output speaker, driven by a 10-watt amplifier, provides onboard audio playback, and closed caption display is also available.
Simplifying operation, the unit powers on once the power cord is connected to AC power, with no need to operate a switch on the projector or even the remote control. Reflecting SANYO's commitment to energy efficiency, the PLC-WL2503 is compliant with European EuP power consumption standard LOT6, and the projector is covered by a three year parts and labor warranty.
TAD ME1TX-SW Stand-mount Loudspeakers Silver Pair Lifestyle
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Shanling CR60 CD Transport Front Angle Silver Shanling CR60 CD Transport Front Angle Silver
CD Players
The Shanling CR60 provides CD playback and ripping capability for a very reasonable $299, but it requires an external DAC.
Cleer Audio ARC 3 Gaming Edition Open-Ear Earbuds Cleer Audio ARC 3 Gaming Edition Open-Ear Earbuds
Earbuds & In-Ear Headphones
Priced at $234.99, the Cleer ARC 3 Gaming Edition comes with a USB-C dongle for low latency wireless gaming.
TCL/CSOT IJP OLED Exhibit at CES 2025 TCL/CSOT IJP OLED Exhibit at CES 2025
Monitors
TCL's CSOT Display Company Mass Produces First InkJet Printed (IJP) OLED Monitor through new Apex Technology Brand Label.
FiiO Snowsky Retro Nano Portable Music Player White FiiO Snowsky Retro Nano Portable Music Player White
Is FiiO’s lineup of Dongle DACs starting to cannibalize itself? The addition of aptX HD and LDAC support makes this more of a bargain.
Chord Company Leyline2XL Speaker Cables Chord Company Leyline2XL Speaker Cables
Audio Cables
At £10 per/meter, the Chord Company Leyline2XL are 14 AWG speaker cables designed for custom installers that require long cable runs.
Christmas Gift Guide 2024 for Hi-Fi, Headphones and Home Theater
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
