Sanyo PLC-HF10000L 3LCD 2K Projector
SANYO NORTH AMERICA PROJECTOR
Large Venue Projector With QuaDrive Technology Achieves Real 2K Resolution With 10,000 ANSI Lumen Brightness
Sanyo introduced the world's first QuaDrive projector with cinema required Real 2K resolution, the PLC-HF10000L. With 2048 x 1080 resolution that exceeds the requirements for Full HD resolution, and SANYO-exclusive QuaDrive technology, this native widescreen 3LCD projector produces an incredible 10,000 ANSI lumen brightness with a very wide color gamut, advancing display capability for the mid to large venue presentation market.
The QuaDrive engine adds a yellow color control device to the red, green and blue elements of the projector's 3LCD system. By automatically controlling the amount of yellow light in the image, it improves color accuracy, produces a wider color gamut and enables higher brightness levels. First introduced in 2008 in the PLC-XP200L, in 2009 the technology demonstrated effective color output even at the high brightness level of 12,000 lumens with the PLC-XF1000 model.
The PLC-HF10000L is SANYO's first QuaDrive projector capable of Real 2K resolution, with no image compression. Its dual high-output lamps are used in combination with three internal mirrors that produce uniform light output, reduce color irregularities and produce exceptional image quality even at the remarkably high image brightness of 10,000 lumens.
SANYO's Durable Inorganic Optical System (D.I.O.S.) works in tandem with QuaDrive to produce a 3,000:1 contrast ratio, producing rich, deep blacks and high-resolution image clarity, as well as extending optical system life. Low total cost of ownership (TCO) is further advanced through SANYO's Active Maintenance Filter (AMF) system. AMF aids long-term reliability and reduces maintenance costs, by monitoring the intake air volume through the filter and automatically advancing the “cartridge-like” filter media to provide a clean surface once reduced airflow through the filter is detected.
Nearly a dozen lens options provide great flexibility to fit venue requirements. Fixed and zoom lenses in standard, wide and long configurations are available, and remote controllable powered vertical and horizontal lens shift facilitates installation in nearly any environment.
Where multiple images are required, the PLC-HF10000L can simultaneously display two images, in either picture-in-picture or picture-by-picture modes. When additional projectors are required, its Color Matching function corrects variations in hue when more than one projector is used, and Edge Blending allows multiple images to be presented on the same screen without sharply defined borders, such as when more than one projector is used to create an extremely large image.
SANYO's PJNet Built-in LAN networking facilitates control of the projector or a group of projectors through standard CAT5 network cabling. For presentation applications where necessary, a mechanical shutter system allows operators to instantly shut off light transmission. Input options include HDMI 1.3; DVI-D; D-sub 15 pin RGB; BNC for RGBHV and CV/Y-Pb/Cb-Pr/Cr; and S-Video, with optional boards available for HD/SD-SDI and Dual Link SDI.
Price and Availability
Available in November 2010 the SANYO PLC-HF10000L has an MSRP of $34,995.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
