SANUS Elements Super Slim HDMI Cables
The new SANUS Elements Super Slim HDMI Cables offer an ultra-flexible design and shorter connector heads, which make it easier to connect the cables in tight spaces, such as behind mounted ultra-thin flat-panel TVs.
The cables feature connectors that are 40 percent shorter than the connectors of conventional HDMI cables, and an ultra-flexible design enables easy bending. These features are especially significant for use behind mounted TVs where space between the TV and the wall is often limited. With SANUS Super Slim HDMI cables, a TV could be mounted nearly flush with the wall and still allow cables to be attached behind the display. An additional benefit, SANUS Super Slim HDMI cables are Ethernet enabled, allowing for high-speed Internet connectivity and media streaming, and eliminating the need for a separate Ethernet cable.
Other features of the SANUS Elements Super Slim HDMI Cables include:
  • 4K x 2K Support: All models handle 1080p video resolution for next generation displays
  • Deep Color: Cables support 10-bit, 12-bit and 16-bit color for deeper, more accurate color
  • 3D Ready: Cables are compatible with 3D TVs and components
  • Audio Return Channel: Enables TV to send audio signals back to an AV receiver or another audio controller for adding surround sound to TV programs
Price and Availability
All SANUS Elements Super Slim HDMI Cables will be shipping in mid-September 2011 in various lengths:
See more about: HDMI cables, SANUS
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
