Memory Cards
SanDisk Extreme Pro microSDHC UHS-I Card Announced
SanDisk announced the Extreme Pro microSDHC UHS-I card offering up to 95MB/sec read and up to 90MB/sec write speeds, claiming to be the world's fastest memory card for smartphones and tablets. The microSD card is ideal for users running multiple apps, while claiming faster loading apps, quicker file transfers and improved overall system responsiveness.
Features
  • Full HD Video Capture: With a UHS Speed Class 1 rating (Class 10 equivalent), the new card allows consumers to record superior Full HD videos, even in 3D
  • High-Quality Photo Capture: Offers up to 90MB/sec write speed for capturing multiple photos using burst mode with a UHS-I enabled mobile device
  • Faster File Transfers: With up to 95 megabyte per second (MB/sec) read speed, the card moves files quickly between host devices
  • Seamless Multitasking; Fast Downloads: The card allows consumers to smoothly run multiple applications at the same time and download files quickly using 4G LTE phones
Pricing and Availability
The SanDisk Extreme Pro microSDHC UHS-I card is available on www.sandisk.com in 8GB and 16GB capacities carrying MSRPs of $59.99 and $99.99. The card is compatible with any microSDHC-slotted device and is ideal for UHS-enabled smartphones and tablets.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
