Samsung Announces Smart Monitors for 2023
Sometimes you need a PC monitor and other times you need a TV. With Samsung’s Smart Monitors you can have both.
Samsung Smart Monitor M8
Samsung has already released a wide range of new TVs for 2023 (refer to the related reading section at the bottom of this article) and there is still more to come. However, they also make innovative PC monitors. For 2023, Samsung has updated its Smart PC Monitor lineup which is also compatible with the newest M2 and M2 Pro Mac mini desktop computers from Apple.
The reason that these monitors may be of interest to eCoustics readers is that they offer features that both PC users and TV viewers will like. They are not only great companions for the PC environment, but you don’t even need to turn your PC on to use a number of their features.
Let’s take a closer look at Samsung’s M8, M7, and M5 series for 2023 and see if any of them are the right fit for you.
Samsung Smart Monitor M8 Front on desktop
Tip: Check out our report on the previously released 2022 Samsung M8 Smart Monitor
From David Phelps, Vice President of Product Management, Samsung Electronics America: “When we introduced the Smart Monitor with streaming TV three years ago, we raised the bar for what a monitor could be for entertainment and productivity…Our 2023 Smart Monitors with streaming TV continue to lead this emerging category of smart displays with technological breakthroughs and new screen sizes to fit in any space.
Picture Quality Enhancement: For 2023 Samsung has implemented multiple upgrades and feature enhancements for the M8 including HDR 10+, and 400 nit brightness. The M8 and M7 both support up to a 99% sRGB color gamut.
Tip: The M8 and M7 support 4K UHD resolution, while the M5 series is more limited with FHD (1080p) display resolution. All three series use LED/LCD TV display technology.
Slim Design: The M8 and step-down M7 series have both been redesigned so that they fit nearly anywhere in the home. The new Iconic Slim Design enables the M8 and M7 to have a flat, super slim 11.39mm thick frame. The ergonomic, slim design provides workspace utility and style. The back of the M8 and M7 displays have a herringbone pattern design.
Samsung Smart Monitor M8 vertical in kitchen
Adjustable Stand: A height-adjustable stand with tilt helps M8 and M7 users adjust the viewing angle. New for 2023, the screen can also rotate 90 degrees to view long documents in portrait orientation.
Gaming Hub: The 2023 line includes expanded Smart TV features such as the Samsung Gaming Hub. This allows users to play games from several streaming partners (Xbox, GeForce Now, Utomik, Luna, Antstream, and Blackout), with no PC or gaming console needed. The monitors also continue to offer popular video streaming apps like Prime Video, Netflix, and YouTube via Samsung’s onscreen Smart Hub interface.
Samsung Smart Monitor M8 in home with smartthings
Smart Things Hub: In addition to the Smart Hub streaming interface users can connect, control, and manage hundreds of compatible connected devices from the Smart Monitors with a SmartThings Hub (built-in on the M8 series, requires a $34.99 dongle on M7, and M5 series). With the SmartThings App, users can turn off lights, adjust the thermostat, and more.
Voice Assistance: The M8 and M7 also include built-in voice assistants, including Bixby and Amazon Alexa, for easy voice control of the monitor. The built-in mic supports Far-field voice capability, allowing users to speak directly to the monitor.
Tip: Voice assistance is not available on the M5 series.
Samsung Smart Monitor M8 angle
My Contents: Now available across the 2023 Smart Monitor lineup is My Contents. This feature allows users to access helpful information such as photos, schedules, calendars, weather, and more… Also, when the monitor is on standby mode and detects a registered smartphone through Bluetooth Low Energy (BLE), the screen lights up with the user’s photos, calendar, weather, and other info. The monitor resumes standby mode when the smartphone is out of range.
Camera: The M8 has a removable, magnetic camera (SlimFit) so users can connect wirelessly with no additional camera purchase ($99.99 to add it to the M7 and M5 series). The SlimFit camera supports FHD (1080p) resolution. Video conferencing features with Google Meet and other apps are supported. In addition, Auto Framing keeps users in the center of the frame, even when they move.
Multi-View: For 2023 Multi View allows you to use Microsoft 365 and the Browser app in full-screen mode to reduce switching between apps.
Apple Connectivity: Samsung Smart Monitors can wirelessly connect to Apple devices to view content from an iPhone, iPad, and Mac on a bigger screen.
Tip: Samsung Smart monitors can be connected to a Mac Mini as well as to a PC.
Wired Connectivity: With four ports, users can connect completely to the Smart Monitor without any adapters to charge devices, transmit data, or make the most out of a multi-screen setup.
Keyboard and Mouse Control: To enhance the interface of all the 2023 Smart Monitors, mouse, and keyboard control functionality has been added to many apps, including SmartThings and Smart Hub. Users can now maintain full control while exploring their favorite content without needing a remote.
Samsung Smart Monitor M8 front with remote control
2023 Samsung Smart Monitor Comparison
Series/ModelM8/M80CM7/M70CM5/M50C
MSRP$649.99$549.99$279.99
Display TypeLED/LCDLED/LCDLED/LCD
Screen Sizes32 and 27-inches32 and 27-inches32 and 27-inches
Aspect Ratio16×916×916×9
Display Resolution 3840 x 2160 (UHD)3840 x 2160 (UHD)1930 x 1080 (FHD)
Average Brightness (NITS – cd/m2)400300250
HDRHDR10/10+HDR10HDR10
Refresh Rate60Hz60Hz60Hz
Response Time4ms4ms4ms
Contrast Ratio3,000:13,000:13,000:1
Smart FeaturesYesYesYes
Voice AssistanceYesYesNo
SmartThings IoT HubBuilt-inRequires DongleRequires Dongle
Multi-View2 Full Screens2 Full Screens2 Screens
Stand TypeHeight Adjustable/Pivot/TiltHeight Adjustable/Pivot/TiltStandard
Wall Mountable YesYesYes
Adaptive PictureYesYesYes
Eye Saver/Flicker Free ModesYesYesYes
HDMI Inputs1 (ver 2.0)1 (ver 2.0)2 (ver 1.4)
USB2 (type A) – 1 (type C)2 (type A) – 1 (type C)2 (type A)
Speaker System5 watts x 25 watts x 25 watts x 2
CameraIncludedOptional (pogo ready)Optional (generic)
Remote  Control Included (USB-C Charging)Included (USB-C Charging)Included (USB-C Charging)
Samsung Smart Monitor M8 on-wall
Availability and Price
M80C
  • 32-inches: $699.99 (Warm White, Daylight Blue, Sunset Pink, or Spring Green)
  • 27-inches: $649.99 (Warm White, Daylight Blue, Sunset Pink, or Spring Green)
M70C
  • 32-inches: $599.99 (Warm White)
  • 27-inches: $549.99 (Warm White)
M50C
  • 32-inches: $299.99 (Black, White)
  • 27-inches: $279.99 (Black, White)
The 2023 Smart Monitor line will be available starting in June on Samsung.com and at select retailers nationwide. The previous year’s Samsung Smart Monitors are now 20-40% off at Amazon.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
Shopping for a new TV? Our picks for best televisions of 2024 provide the best picture quality and value at their price and size.
Compare every 2025 ultra-short throw (UST) 4K projector to decide which one is right for you.
Samsung’s new Movingstyle lineup brings mobility to the living room with the 27-inch LSM7F and 32-inch M7 Smart Monitor, combining style, flexibility, and power.
Ask an Expert
QD-OLED TVs blend OLED’s perfect blacks with Quantum Dots for brighter, more accurate color. Here’s how they work—and what sets them apart from regular...
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
Four flagship OLED TVs enter a dark room. But only one can emerge the winner.
