Samsung SE-B18AB Portable DVD Writer
Samsung just announced a new slot-in, slim portable DVD writer, the SE-B18AB optical disc drive (ODD). The slot-in system allows easier loading and unloading of discs. Without the need to open or close the tray, the drive will swallow the disc automatically. A simple push of a button will eject the inserted disc.
The SE-B18AB is designed for laptop users, with limited USB ports. Thanks to Smart Power Technology, only a single USB cable connection is sufficient for running the SE-B18AB.
An AV Connectivity tool allows the SE-B18AB to function as a portable data storage device when it is connected to USB-connectable tablets. A technology proprietary to Samsung, AV Connectivity is an ideal solution for tablet users who want to enjoy multimedia content stored on optical discs.
The SE-B18AB is also equipped with Smart Archive Technology which helps store personal data safe and sound. Unlike existing optical disc archive technologies, the SE-B18AB follows the standard DVD format, making it compatible with archival discs (ISO10995 standard) and qualified normal discs.
The drive is engineered to run on widely used operating systems, including Windows 8 and the latest Mac OS versions, and is capable of reading and writing files at a variety of speeds across different data media types. Using Buffer Under Run technology, the drive works to prevent errors that result from writing speeds that can exceed data transfer speeds, while also enabling PC multi-tasking.
The SE-B18AB is an eco-friendly product, manufactured with lead-free soldering technology that eliminates harmful materials such as Pb, cd, cr+6, Hg, PBBs and PBDE.
Price and Availability
Samsung SE-B18AB is available now for $49.99.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
